- Vtec/ecu/harness questions???????
- Well..Simple question needs answering :-)
- LS swap ?
- WTB 96-00 civic manual window regulator 4door
- My car caught the gay...
- ys1
- 95 civic ex door speakers
- ** Florida CRX Meet PHOTOS! ** Dial-up beware!
- vtec controller/vafc
- running vacuum lines for boost
- how much compression is to much for nitrous
- installing a lip?
- Separating a 3 ply ls head gasket
- need some help
- if i wanna make REAL POWER n/a on a d-series....
- anyone had any experience with ebay d series cold air intakes..?
- guage cluster not working
- HELP ME PLEASE!! h22a4 block with h23a1 crank....
- Supercharger for D17A2?
- how to boost ls
- i need help put a y8 head on a z6 block
- Need timing help ASAP
- Can i duplicate my car key...and how
- f22a1 longblock
- ls/vtec clearance issue
- SOHC cam turbo setup??
- Having PROBLEMS with Vtec!!
- Crx Meet Pictures
- Engine Build Question (Help)
- Final drive question
- EK Hatch Exhaust??
- Ek hatch intake???
- Short shifters
- Fuel Pressure Regulator
- clutch question (stupid)
- d16z6 turbo question
- Hairline crack in camshaft lobe
- Mixing ACL Bearings with OEM?
- ANyone know where I can get EG carpet?
- Rsx Lsd
- D16z6
- pictures from TRack Day 12
- Thanx
- Rep ^ Accords
- LS/vtec question
- The Official Track Day 12 H/A times...post em up
- 91 Ls Power Steering
- Anbody running an exhaust with a dynomax thrush muffler?
- Head Question
- Need EG fuse panel diagram ASAP!!!!!!!!!!
- S2000 performance?
- directions to the bradenton motorsports
- i need to know why
- Q for mtber
- 95 EX head
- Prelude Wiring?
- Phucked up math!!!
- Looking for crx bumper
- turbo manifold question
- My alt belt flips and breaks...
- directions to bithlo
- My Hybrid Build F22a1 bottom end H23a1 head!
- Accord LX weird idle problem
- Piggyback systems worth the money?
- jdmcarboy.com anybody ever use them?
- Main relay/Fuel pump relay? 93 civic lx
- valve cover chrome
- Throwout bearing help
- Who Needs Money in St. Pete (install)
- which spring compressor works on a teg?
- help! How do you get illegal window tint off?
- trunk alignment issues... 99 civic coupe
- car breaks up at high rpm
- dual point to multi port
- '94 honda accord clutch
- 2006 civic si
- best sounding exhaust for a D16?
- Help with swap
- help with speedo
- HELP: Suspension preferences..
- Broke Lug Nut... Help Fast
- Places to get Clutch replaced in Orlando????
- questions on mini me swap
- Hmm, low on fluid??
- Need some ITB's
- Prelude Help
- B16 VTEC hefad on a LS
- Where to get GM Synchromesh locally?
- The St. Pete/Clearwater rollout to track day offical thread...
- Knock Sensor
- need someone to do a swap cheap......
- In need of a good valve adjustment..
- 05 Si header
- Safe or no?
- Can I put an LS cylinder head on a b16 block?
- Motor Letters
- SOHC Cam Timing
- Chavez Motorsports TRack Day roll out!!!
- ROOOLLLLLLLL OOOOUUUUT!!!!!! (to TRack day!)
- v-afc help?
- **{Körbach Frame Locks}...Skeptical....yet Interested!?!**
- Need a welder!!!
- LX, EX vs DX :opinion please
- turbo question
- **Need some Clutch brand advice (B-series)**
- D15B v. B16A2
- Question to you battery specialists out there
- Which Axle?
- honda help please..
- Exploring My Intake Options
- Axles, for B18A in 90 SI
- pics of the b16a in the 4 door eg swap
- b16 head
- questions about eg dashes
- Fan wont turn off
- Looking for someone who does anodizing.
- Trackday Spot Wanted!!
- bseries SWAP Deal on drivers side mount from autozone
- Looking for a shop/garage, 500-600sqft
- o2 sensor
- How do I get rid of this?
- Hondata s100
- Plastic Cleaner or other headlight cleaning techniques?
- Good Tire and Wheel Shop
- Name your best Honda/Acura clothing artical
- Clean Engine swaps
- engine crankover/valves hit?
- G2 HID conversion question.
- which car?
- OK people, lets find out what is wrong here....
- Radiator Question
- new honda owner
- building ls head
- Any one have a SC prelude??
- what do you guys think of my new setup
- arospeed crank pulley
- tuning
- Got some new wheels ,exhaust/headlights and motor **pics** 56k go do a swap.
- Are front mount intakes worth it?
- vafc ?
- ecu's
- I want to swap a ls into a 94 civic
- Best aftermarket cams for GSR
- Red DC Integra+ JDM Front end on 275N
- where to get parts.
- 450cc dsm injectors ?
- Need Help Asap! I Need 1 Stainless Brake Line
- f22vtec/ f22 non vtec ???
- D16y8 CRX Swap (help)
- hondata q
- radiator question
- have i gone to far NA to turn turbo????
- oem type r or aftermarket parts
- painting a cf hood
- So whos all ready for TRACKDAY?????
- D16Y8 head HELP
- Catch Can Questions
- Wheels.... Help. Wheel GURU's where are you?
- What's good to clean my carbon fiber hood?
- ECU ISSUES some body help
- looking for carbon parts for 94 4 dr
- projectors/halos?
- 94 Accord Read Disc Swap
- Help Finding Corey Thompson
- Code For Radio
- turbo question
- Ferrea Valves...
- Reputable Honda shop
- Cheap Odysey motor?
- cant figure out what is causing vibration.
- it surges
- TYC headlights
- 06 Civic SI
- help: decision on what ecu to use...
- b18b turbo build options
- SRS Light.. Question
- Is this block salvageable?
- b16 ecu and vfac for sohc v-tech question
- help with my 94 accord
- ep totaled
- Del Sol with scissor doors.
- Turbo set-up Opinions/experiences. go or no-go?
- how difficult to make ek hatch front end into a teg?
- where to get parts in sarasota/bradenton for my ek hatch?
- Check engine Light Came On...
- whats best?
- coolant leak
- help wiith turbo
- Need help w/my 1995 Accord
- Stupid Cam Question
- iac valve problems on my turbo GSR
- Dang VAFC 2 pulling codes??
- Lesson Learned: Cooling System
- Integra air bag Q
- how to get performance for free?
- cam install question
- b18 axles??? help
- ECU Identification
- Just got back from the track....
- CatBack
- how do I pull out the studs on a intake maifold
- Catch can filling up
- Just saw this and i was impressed **h series**
- What is the code for an si tranny 92-95 ?
- Piston to deck height....**question**
- what next?
- air/fuel gauge help w/ h22
- roadside assistance
- EG hatch door leaks
- hmmm what ecu?
- CRX is comming back!!!!
- Need Help With My Ls With A B16
- need help!!!
- low or high impedance injectors
- Has anyone out there modified a CRV?
- Have some Engine Questions.....
- 91 civic hatch
- turbo question
- Preview to the SOHC Vtec TURBO build thread
- Replacement "Tuner" Lug Key
- pics from the nopi event last weekend
- New pics of the integra
- POLL does this help?
- brake caliper ?
- need help for my car about an engine for a honda
- intermediate shaft screwy?
- Wiring Help Please
- Hose opinions please
- Code 19, will this effect my performance
- cheapest place to get turbo installed?
- Help Me
- I got a code
- super DUMB intermediate shaft question
- Lucas tranny fix??
- Urgent!!!!!help!!!!!please!!!!!
- Let's play NAME THAT PISTON.
- Vtec lotus
- Last suspension question, I swear.
- D16Y7 Head Swap Question
- Help With My 1999 Honda Civic
- JDM P13 speed governer
- Big Nopi Race Video From Saturday
- New rotas....
- Honda Drag Rims
- Clearance issues?
- Pics.. opinions please
- Starter/flywheel clearance
- LS block - lsvtec
- B-series vtec valve adjustment
- !READ!Transmission problem!!!! NO!!!! READ!
