Catch Can Questions
What do you guys feel is the best Catch can for a (400-500hp vehicle) I've seen the ones on Ebay, Greddy, Endyne, and moroso with the breather. I'd like to hear from experience. I hear people say the ebay ones are garbage, but how so. Technical insight would be paramount.
JDM Hater #001 PITBULL, "the most diabolical JDM/all around HATER"
It's not that the JDM itself is bad. When everything is JDM, When you think you're JDM, When your US car is JDM cause of your taillights. When YOU are JDM. YOU are GAY!
Its all in how you hook it up man... The Endyn Kit is great, but you can pretty much use any Moroso/Jaz/etc. vented tank, the same way... its all in how you hook it up.... Just happens to be the Endyn can comes with the best instructions on how to properly install it, with the best results...
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
i made my own from ACE performance...i mean ACE hardware!
3 inch pvc pipe-5 bux
two 3 inch end caps-3 bux
two barbed niples-2 bux
one ghey ricer mini filter from the "zone"-8 bux
eight foot of line-5 bux
23 dollars and youre good! i use to smell that gasy/oily smell, but now i dont.
and they way i hooked mine up is about the best way to pull crankcase pressure out under any type of throttle
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
Cant forget the steel wool
honda-tech.com search is your best friend
Originally Posted by boostedb16a3
care to elaborate?
Use the biggest ID hoses you can find, and run more than you think you need.
Put the biggest breather on it that you can fit. That way the engine
can breathe with *no* effort...........which is the purpose of the can.-Bob
