Catch Can Questions
Old Oct 19, 2005 | 12:40 PM
NChatch's Avatar
i stepped on my weiner!
ill take some pics for you
pics of the can/filter/brass fittings and line
pic of vaccum source, this source on a turbo car will ALWAYS pull out crankcase pressures, even in boost.
there is another option, you can use what is called the "bernouli effect" which is a small pipe inseted in the exhaust, which is slash cut at 45 degrees causing pressur to pull the crankcase excess from the motor.
if you leave you set up stock, with a pcv valve, then when going into boost you will always shut the system off and actually keep the motor pressurized doing more damage than good.
with "bleed off systems" or "natural draw" systems which only dump into the can there is a downfall, if your crankcase pressure isnt strong enough to make it all the way to the can, and only builds up in the line, then you have an issue, it never really goes anywhere, just travles back and forth in the line
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Oct 19, 2005 | 04:05 PM
NChatch's Avatar
ttt for pics
owner/operator
Old Oct 19, 2005 | 08:05 PM
boostedb16a3's Avatar
Equal Opportunity Hater
thanks for the pics. that is what I meant by elaborating thanks again mang.
JDM Hater #001 PITBULL, "the most diabolical JDM/all around HATER"
It's not that the JDM itself is bad. When everything is JDM, When you think you're JDM, When your US car is JDM cause of your taillights. When YOU are JDM. YOU are GAY!
Originally Posted by JAVIELITO
limpio as fukk
Old Oct 19, 2005 | 08:07 PM
mtber's Avatar
Mike, your such a nice guy
Old Oct 19, 2005 | 08:25 PM
95gainfla's Avatar
smokes weed...everyday.
since we're talking about catch cans and crankcase breathers.....
can someone actually educate me on what this is, and what it does? ive seen cars with a small breather located on the top left of the valve cover on what used to be a vaccum line to the intake mani, but im not sure if that is it? if not, what is that?
thanks.
I <3 RooR!!!!!!
Old Oct 19, 2005 | 10:59 PM
Shit if Mike got away with the ace performance catch can then ill just pick up the ebay one for 25 shipped. Nice polished looks, cheap, and like insanecivicsedan stated its how you hook it up. Im gonna get er done with the ebay one. Does that sound about right? It seems that people are just paying for the name with this particular mod.
limpio as fukk
