questions about eg dashes
Old Oct 24, 2005 | 07:17 AM
94lsteg's Avatar
BOOST IS BETTER!
Default questions about eg dashes
Will a 2000 si dash/centerconsole fit into a EG?
Old Oct 24, 2005 | 09:36 AM
The Spectacle's Avatar
Spent more money than you
but i'm sure anything can be made to fit with enough time/patience/money
why?
Racing Integration
LHT Performance
My tuner is named Alpha
Old Oct 24, 2005 | 01:35 PM
94lsteg's Avatar
BOOST IS BETTER!
....will it fit? ttt
Old Oct 24, 2005 | 01:37 PM
B18C5-EG's Avatar
why?
Thats obvious
Cause he wants to?
You will have to prolly get the EK AC Ducting system, cut the top front bar brace, do some cutting/fabbing to the door pannels, and some other things i cant think of off the top of my head.
Old Oct 24, 2005 | 02:30 PM
CEMAYHALL's Avatar
www.CEMayhall.com
I called you earlier tonight about my set-up... well.........Damn bro... I guess I was wrong??? I suck!!! After reading up on it, Its really simular to the integra/GSR dash swap that everyone does!!! There are a couple of different things that you need to do though...
You need to make special brakets for the side dashboard mounts! You alse need to change out the entire air box vents, and also change out the underdash wire harness... You will need to cut the door pannels just as you need to do in the integra dash swap...
under the dash view for the EK
under the dash view for the EG... Notice the air box difference???
these are the side mounts
these are the special brackets that you would have to make
these are the brackets mounted
You will aslo have to modify the bracket by the steering wheel so the dash sits correctly
Finnished PRODUCT!!!
??? Bro!!! I hope this helps you out a little??? Good Luck if you decide you want to do it!!! Post pictures when youre done!!! Cya!
Old Oct 24, 2005 | 02:37 PM
CEMAYHALL's Avatar
www.CEMayhall.com
oh yeah... Rep points too cya
Old Oct 24, 2005 | 04:49 PM
94lsteg's Avatar
BOOST IS BETTER!
holy shit, nice bro. Rep points for you,could u link me to that link.
Old Oct 24, 2005 | 06:34 PM
DavidEK's Avatar
drives a truck
+1 rep points for you, thats sick. How much is that going to cost? ill take 2 of those!
Old Oct 24, 2005 | 06:38 PM
DavidEK's Avatar
drives a truck
doug if your going to do this LMK. I want to it with a teg dash.
Old Oct 24, 2005 | 06:41 PM
CEMAYHALL's Avatar
www.CEMayhall.com
ok but only b/c I am being nice!!! I hope this helps you out a little... http://www.honda-tech.com/zerothread?id=1380608 cya
