View Full Version : Honda/Acura Tech
- skunk2 with ctr?
- Knock sensor...
- My poor motor....
- OBD2 chipping?
- Wings?
- who has the fastest honda on TR
- Roof Antenna Conversion
- Tranny
- looking for jdm itr rear lca's
- Attention Acura Owners - car club meeting
- d-series T.B.
- Is this a knock off version of str?
- obd1 conversion
- Valve Adjustment on a b18b head
- Motor Swap Shops
- Stripped coil screw
- Leaking oil
- Oversized throttle bodies...
- Can a N20 bottle be mounted like this...(pic)
- need opinions!!
- GSR to Ex guage cluster fitment and conversion...
- remanufactured part yes/no?
- Hood Clearance????
- How much would a b20 bottom end cost?
- b16 to b18c1
- d-16a6-head swap to z6 questions{mini me}
- nuspeed springs??
- Problems with my car...
- Problem with summit rpm switch...
- Phantom Grip
- $420 cash+ a lick on the nuts to whoever can answer me this
- Low compression... too low?
- wtf is a d15z1...
- need a bad O2 sensor....
- cheapest place to find vafc
- Tampa Bay Prelude Club?
- A/F ratio guage question
- ''Help on Pulley Removal''
- Turbo Size?
- detailed 99 teg info, any sites?
- Anyone have an engine hoist?
- n00b needs assistance
- Werd????
- best cams?
- Tie rod or rack and pinion
- feul help please!!!!!
- what clips to use???
- dipping out
- Touchy in here aren't we ?
- what ecu and harness do i use im going fucking nuts!!
- Check engine light...
- FLORIDA CRX MEET - Sunday, November 3rd
- need help with a motor swap
- All Motor or Supercharge
- goddamn ignitor
- speed sensor ¿?¿?¿?¿?
- front seat to rear seat conversion... take a look
- Need Help!!! H22A in 94 Civic
- Throwing a code 14
- 93 LS in a 92 cx hb. what do i need??
- short shifter? order for the car or for the motor in car??
- what exact mounts do i need????
- what obd1 injectors should i use??????
- Wiring harness question
- swap questions
- spliceing o2 sensor wires
- Will a 92 cx timing belt fit a 92 lx?
- I need help with my toe............
- **FIXED** SRS light STILL won't go off...please help!
- where to get hood clearcoated???
- gs-r header
- Smoke out the exhaust
- Just curious about my b18a1?
- Header Problems
- tein coilovers/rear discs
- VX rims...problems fitting certain cars?
- get rid of power steering?
- Tanabe Racing Medallion on Rsx
- crank pulley removal
- Machine shops in Tampa/Clearwater area
- Civic issues.
- GM 3 Bar MAP sensor
- 92-95 CX hatch, A/C question
- b18a2
- leakdown tester.....
- i need wiring done
- Shin Dig
- ? whats the code for 95 gsr.........
- obd1--to--obd2
- lsvtec and p28
- Help new car.
- Need help with broken drive axle!
- gsr crank
- exhaust problem
- Question
- Racing Integration?
- my tach is retarded.....
- good honda site
- Open your hearts and lend me a crankpulley wrench...
- Bucking and hesitation...
- RIPPED OFF!
- NGK
- Cam pulley bolt.
- ECU Help
- Rods on a ls/vtec
- Need a 2nd, 3rd, 4th opinion!
- Does anyone get a hook up with OEM Honda parts?
- I'm just a dumb mullet...
- 460cc injectors
- crx with b20?
- 2000 Integra GS-R A/C compressor shutoff at WOT?
- Anyone know of a local source for JDM CRX SiR front ends?
- MPFI 88/89 crx hf???
- white s2000
- Porting a Z6 manifold to match an LS TB
- cooling porblems on B16...II
- Exhaust Help?
- AHHH MY BALL....JOINTS!
- integra/civic crx-center console compatability
- My next purchase for my car
- Dunk muffler?
- Question about short shifter!
- crx
- WHATS HOULD I DO ABOUT TURBO????
- Race Related Turbo Manifold, good?
- PLEASE HELP!!!
- RSX Type-S/CTR K20
- rear disc questions
- Silencer....
- Steering Problems
- Red 92-95 Coupe Civic w/ GSR Sawblades and a Apex-i (v)AFC
- Wiring Questions
- Once again i need serious help asap...
- Question abotu belt sizez
- CRX Motor Swap Q's
- ¿?¿?question for JDM ballers
- drop kit system
- cooling problems on B16....
- <<<HELP>>>
- Ecu install
- HELP: Bolt stuck on tranny and is starting to strip
- question on 00 gsr interior
- type r vtec lobe specs
- Is it my clutch?
- Timing belt
- Rod encaps... a blunder...
- Help on 93 accord swap.
- 2002 Honda SI
- integra 4wheel disc on my 93 CX(questions)
- Spring/Shock Installation
- stock Integra spoiler
- 98 itr specs
- little engine problem
- D16Z6 and D16Y8
- SOHC Bored motor + boost...
- Service limit specs
- Will this work?
- cams to run on a bottle feed B18b?????
- Running too Rich
- rebuilt 95 accord
- VTEC solinoid(sp?)
- Purchasing Header
- trade altezzas
- shock install
- Where do they go?
- need help with engine problems
- Shocks shocks and more shocks
- port and polish
- Cylinder wall trouble...
- WTB ZC ENGINE
- Easy brake question..
- JDM Steering Wheels Q's
- Buying parts for b16?
- Si Vs. EX ecu
- Pre-swap Preventive maintenance?
- Where to get rims painted/powdercoated?
- help...damn tranny bolts wont budge....
- Help! B16a1 into 90 civic dx!
- ? wiring harness
- ok TACH, better?
- Pics from my engine rebuild...
- i need a intake cam for a 90 -93 non-vtec cheap!!!!!!!!!!
- DX motor HELP
- Best 215/40/17 tire?..
- Radiator fans
- Steps to storing a car !!!
- 99-00 Civic Si Taillights
- obd1 swap questions
- Block posting,good or evil?
- are bseries gears/syncros interchangable??
- valve to piston clearance....
- engine check light and speedo actin up...
- thoughts on short shifters??
- tack.....
- NEED HELP WITH FPR
- checking ecu codes
- shift linkage
- Swap questions
- I think Im fucked
- is there any difference??????????
- Question about fluidyne radiator......
- swapped CRX to be sold soon, $$$???
- KYB GR-2 shocks for me teg???
- Skunk2 Camber kit
- OIL
- Just wondering about strut bars?
- ek hatchback question
- Ineed a head gasket BAD!!!
- I need to balance my wheels
- Need help building one hell of a suspension
- integra shifter bushing
- How to bleed cooling system on my B16...
- I'm the man!
- no spark
- help
- cleaning in and out of head
- Motor HELP!!!!!!!!!!!! please!!!!
- Z6 install into crx...need someone to do it.
- Injector sizes and hp values...
- Wanted: 91 CRX SI ECU
- gs-r block-b16 head?
- tranny whats a good choice
- Stock body parts ..
- hybrid tranny
- The Lude guys always get screwed and left for last
- cam gear
- sparkplugs??
- Question about my specs
- Intake question????
- Changing pistons rings?
- WTF DAMN THE DEVIL, AH MAN So Your Telling Me What?
- compression on a B16...
- radiator fan motor....
- Cold Air intake on a '93 hatch
- **ATTN.**5th gen civic w/b16swap owners!
- Wanted pre OBD DX ECU
- What now?
- PnP 16valve engines...
- A good sohc swap..
- couple prob. with sohc ex
- Where to find walbro fuel pump
- Milled cylinder head ............................
- Views on a B20/VTEC
- greddy evolution exhaust?
- Problem
- a/c volts
- [b]Which motor??[/b]
- What Drag Radials will fit 95 Ex rims (steel)
