View Full Version : Honda/Acura Tech
- H/A gives a big Thank You to...
- H/A meetup review
- H/A dyno day charts
- i need help from a honda h22 GURU!!
- H22 swaped in hatch
- Ls/Vtec question
- White Civic going to Bradenton
- honda acura meet up tommorow
- jdm b18b
- opm motorsports lsd..any experiences?
- ls question
- D17 swap
- Need Help!
- Would some moderator please go through and delete all the really stupid questions tha
- i've made my decision to go with turbo i'm going to secret services any thoughts !!!!
- gsr seats in hatch
- Interchangable interiors
- Completely False Info
- Accord, has air bubbles in brakes?
- 98 Integra GSR idle problem
- Aftermarket gauge locations in a 92-95 Civic
- Dsm injectors?
- Bad ass D series
- b16 into 94 hatch dx
- b18c1
- Convert My Hatch To Crx Frontend
- Hondata ECU question
- b16a into 1994 teg
- ls/vtec set up
- ls vtec set up
- Integra bumper cover (bra)
- re using headbolts?
- add hp's
- CRX suspention???
- Accord Swap
- motor dealers
- Need Help With My Tack!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Integra Dash Into 93 Ex
- port and polished heads
- CRX mini-meet ride out
- Brembo blank rotors?
- ecu help
- crank windows
- itr injectors in gsr?
- Window help
- exhaust help!
- b16 swap into crx.
- SOHC VTEC Turbo
- spoon headgasket
- driver side airbag
- testing waters
- Need b18 head milled, p&p quick....
- Purchasing New Interior.
- how much hp?
- Painting wheels... ?
- Ls Problem!!!!
- 1 week till the H/A meetup @ SS
- B-series sleeves
- Price For Ls Mesh Rims?
- water pump?
- Vibrations @ 40-55 MPH?
- sheet metal dash
- Need gas cap asap!!!
- Ls into 92-95 hatchback
- Yesterday, was the most craziest day ever
- Where to buy Rota's new in Tampa
- Taillights not working --> Checked fuses & bulbs, any ideas?
- spoon stroker kit?
- swap???
- GS-R Cluster into 93 dx hatch???
- LCR ECU's ...
- Sticking caliper how do i fix it?
- Looks
- Block Guard
- trade my swapped crx for integra
- ECU pins
- LHT bseries mounts...
- l.s.d.
- Best places to buy Radiators ?
- ECU Upgrade!!!
- turbo/all motor !!!!
- quick ecu question
- ecu code
- When is a cam just.... TOO big.
- who took their A/C out of their integra?
- 7th gen gude cams
- harness
- WHAT IS CODE 7 ON 89 CRX SI? tps?
- put together a turbo kit for b series
- Drag manifold
- the cam is a bitch
- Anyone want $$ to put a new head on my '94 Tegra LS?
- Need A # Asap
- What 4dr would you do for $9k?
- tranny chart/gear ratio chart
- which mounts..help?????
- need help, ecu codes
- Hasport conversion harness...
- apexi world sport exhaust issues
- factory radio, please help!!!!!!!!!
- help
- nitrous works quick question
- anybody with an rsx around new tampa?
- hatch got owned by water
- b16 dist. re-pin
- Mid pipe
- 90 crx hf motor mount ?
- Turbo piping and down pipe
- Gsr Rear Disc Questions
- My exhaust always smells bad (Not out of my ass)
- How much horse ?
- fitting?
- Vafc
- power/torque of this set up?
- B20a5
- obd0 b16a1 into a 90 ls question
- p28 question
- simple question
- accord
- searching for site
- i know a few ppl have asked
- painting....
- Fiberglass insert
- Vafc
- unchipping a wrongly chipped ecu
- Lots Of Honda Pictures From Gainesville Race
- EX front lip
- Hartman Got HEAD!!! (Pics inside)
- Injectors??????
- 95 gsr idle problems
- b16
- skunk2 stage 2's problem
- Everythin works no spark??? help!!!!!!
- B16a1 Code 22... VTEC pressure signal?
- poppimg out of gear
- what to do ?
- rex
- how much should i charge?
- where should i get an alignment done???
- wont start
- 2 1/2 weeks till the TR H/A meetup
- Tranny probs
- prelude b20a
- Motor Hydrolocked
- do u have a stock p28???????
- putting a clutch in
- Hatchback meet up!!!!
- Now Excepting applications for team whitey!!!
- honda problems
- price question
- 91 Rex ZC Wiring Harness Needed
- oil pump gear
- Skunk mani, fuel rail???
- 93 Si Won't Start???
- CRX swap questions..
- Help with Crank,and need crank SOHC 1.6 Vtec
- HASport Mounts, cheapest?
- Need to Borrow Crank Pulley Wrench!!!
- tire calculator
- the saga continues(it gets worse)
- 3 questions about hatch
- read it and weep
- hitting rev limiter or SOMTHING at 6
- sohc zc supercharged ????
- 2000 Si Suspension....
- Hondata ECU
- help rewiring crx.....
- WTT my 94GSR
- Just wanted to see if some Honda/acura guys were interested
- engine hoist
- Other springs on Integra ?
- Autometer electric oil pressure gaguge install, anyone?
- reputation of Ramseys
- nitrous
- What from a CRX front end works on a hatchback?
- worlds stupidest question
- balance and blueprinting
- Vision Corners........
- Now My Fucking Car Wont Start
- dunno lsvtec
- HX Wheels ?
- rear seat conversion 91dx hatch
- A Revolution for JR superchargers !!
- Jdm 1.5 Vtec
- Is this correct???
- tuning shop
- sunroof
- could someone point in the right direction...
- Stroked Honda?
- exhaust question
- Searching for...
- will 99 GSR tranny fit 93 Si??
- hf / si tranny
- over bore?
- wiring jumper
- 95 integra idle problems.
- Quick radiator questions....
- Breaking up
- Acura CL swap
- crx seats
- Advice on 4th gen air conditioning
- Factory Radio Code?
- for all of you sohc
- Spark Plug wire impedence?
- si tranny number
- What heads will fit a B20A5 engine?
- rack and pinion
- nitrous ??????
- integra question
- CRX rear disc conversion
- exhaust mani to head bolt?
- i need some help with some r-1 sport ground wires.
- Halo Projection lights
- sawblades
- LS valve adjusting
- b16 revving to 4k????
- z6 valve cover on y8??
- prelude into crx swap
- b18b1 into 99 coupe
- shift boot
- seat conversions
- need first gen b16a obd0 distributor
- seat conversion
- peak and hold or saturated
- Who does ECU reprogramming in bay area?N/M
- need opnions
- sohc vtec in crx help
- Avid Racing Mounts
- b16 ac bracket
- TR acura/honda meetup sign up sheet!!
- Vtec
- Anyone using A6 pistons in their D16y??
- opnions
- wiring hell, need help
- looking for a site
- what is hondata?
- Skunk2 cam gears
- food and drinks etc... for the H/A meetup
- ticking problem
- Blue grey smoke..
- My Si lip...
- Help
- turbo
- v-tec vs. non-vtec question
- are crx/civic steering rack the same?
- Left Tire Is Shaking Wtf!!!!!
- Crx fenders and civic fenders..
- PLEASE HELP! (if you can)
