b18b turbo build options
Well I want to rebuild this motor and want it 100% Reliable.
I want it built for boost 10psi Daily driven.
what do you recommed. I have 3k to spend on the motor.
what kinda part do you recommend??
Toss up ideas please.
from the bottom up.
Thanks in advance
Chris
from the bottom up.
Thanks in advance
Chris
10 psi is easily done..just turbo it, an LS can easily handle 10psi daily driven. Just get a nice turbo, manifold, piping, fuel pump, injectors and so on... then just get a good tune.
how far? you pretty limited on the sleeves.. I dont know how far you wanna push the car, but you could do pistons/rods and a block guard along with the turbo and push 18ish depending on the turbo. other then that you will need to sleeve the block which is a little over a grand alone..
If i remember correctly, the motor already has forged pistons/rods.. what more do you want? The next step would be sleeving the block, but if I were you Ide build the head. LS's lose all their power in the top end, considering they only rev to what, 7k? You already have a hefty turbo, so get a nice equal-length manifold, and crower cams/valvertrain and call it a day. (for a daily driven car that is.)
EDIT: one last thing, get john (mtber) to tune it with crome pro after all is said and done.
FLeuro
TheCommision
FLeuro
TheCommision
Forged internals i.e:
Cp Pistons
Eagle rods
New oil itr oil pump
New itr water pump
Itr timing belt
Look into a catch can system such as endyn
Look into tuning...
Another good thing to look into is the health of your turbo seals...
The list goes on. I honestly don't know your setup specs so its hard to recommend specifics.
Cp Pistons
Eagle rods
New itr water pump
Itr timing belt
Look into tuning...
in reference to the catch can: do you feel that the endyne catch can is superior to say ebay catch cans. I'm interested in catch cans but If a catch can is a catch can they why pay 80-90 bucks? Especially when you can get a no namer on ebay for 20-30 bucks.
JDM Hater #001 PITBULL, "the most diabolical JDM/all around HATER"
It's not that the JDM itself is bad. When everything is JDM, When you think you're JDM, When your US car is JDM cause of your taillights. When YOU are JDM. YOU are GAY!
Yes the Endyn system is superior to the ebay cans
Hondata saves lives
Hondata saves lives
The endyn system has a breather filter along with nipples to place in the back of your motor.
