- Ferman Acura
- Rebuild
- Who rebuilds b16a2 axles??
- d16y8 block knockin Q......
- LS head on CRV block.
- tach install...
- FUCKIN ELECTRICAL SHIT!!! HELP!!
- Need help ASAP!!...FIDONZA fidonza fly wheel.
- FPR install problems
- extrude hone?
- What's this JDM thing I keep hearing about ?
- Swap Question on a 2000 Civic EX
- stripped block
- Skunk2 coilovers...its not straight?
- Shotrt throw and bushings into a GSR
- need help with crank timing gear
- AIR bag help, please!
- Will it fit?
- does vetec suck in the 1/4 mile???????????????
- Looking for a picture..........
- place Racing?
- Throttlebody......
- ?? Emissions ??
- This is Florida!! I need AC...
- Jackson Racing?????????
- What 1/4 times to expect?
- Civic and CRX interchangability(sp?)
- Question?
- ls swap into a gsr
- 12" High Flow Cat for GSR
- V-AFC on a non-vtec engine????????????
- Tranny options
- Integra RS vs. Integra LS
- Pic Request - Neuspeed Sports
- ef civic model differences.
- Running like crap at WOT - please HELP!!!!
- Just curious....
- KYB shocks
- ? 92 to 95 SOHC Vtec Axles to CRX ?
- Wheels and springs
- What Shot of Nitrous on a stock 92 LS engine?????????
- How to clean a honda engine right?
- Temp gauge not working
- What To Do Next??
- i need info on mini-me swap
- Stock Shocks???
- 6th gen rear discs.
- about rims, please help...
- click here...
- tach help PLEASE!!
- local shops
- jdm/usdm
- come look at my shaft......not for dial up
- Which SS Brake lines?
- Removal of Stock Emblems
- Camber Kit???
- piston install
- info on 93 prelude
- my hatchback is now running
- suspension ??
- ECU with removed rev limit??
- Difficulty of Prelude injector install?
- Part replacement for Accord
- cam for my D16z6????
- V-Tec or GSR engine???
- shifting
- maximum rev limit for me??
- sc'd gsr
- All motor GSR?
- Exhaust fitment?
- Teg Bolt Pattern
- Need answers immediatly, Dsm injectors in a honda
- What is the max boost pressure....
- Neuspeed Sport Springs
- JDM Effects...
- need help with CV boot
- Older Acura Integra
- 4 into 1 or 4 2 1 Question???
- rattle in the hatch!!! help!!!
- tranny compatibilty
- Which Exhaust?
- G TECH PRO?????
- HAHAHA Read This Is Honda Related....LOL
- vtec into crx swap
- Too much compresion!
- Exhaust question?
- SWAPPING MOTOR
- A/C after my swap?
- Tranny SOHC Vtec question
- Any H22A experts help..
- Need a Litttle help finding someone....
- muffler selection?
- Please help me find inconsiderate asshole
- Anyone willing to.....
- couple questions
- Tuning/Dyno Shop(s)
- Changing wheel studs
- ls\vtec tranny
- civic to integra shock question
- ok i need some answers
- IRIDIUM PLUGS?
- Brake light in 2000 GS-R
- 1.5 Sohc Thoughts
- Valve adjujstment questions
- Can anyone help me install a turbo on my 5th gen(97-01) lude
- shift kit..........
- Loose front end at 90+ MPH
- Model # of Light Bulbs
- siR2 tops out at 90mph
- Noise???
- Gauges Help
- what yr lude injectors should i use with my b16a1 head
- B-series all motor??
- Swap was running, but now theirs no spark
- Timing belt slippin over?
- Slow Type R
- Helix Power Tower
- Just got my car!!!
- Anyone need a .......
- hondata question
- Mounts
- exhaust help
- vibration/grinding question??
- A/C compressor
- sway bars for a 5th gen hatchback
- cable to hydro...
- ecu pins
- How much could i get for my Tranny ??
- OEM injector swap's???
- pleace help with CAI question
- Calling all rare blue 99-00 Si's
- JG 65mm throttle body
- Injector question
- '98-'01('00?) Acura Integra Tails
- intake manifolds
- ls/v-tech ecu question
- Brake pad opinions.....
- Help
- i gotta question bout my GSR
- LS/R Swap?
- I need help with the SOHC Vtec
- b18c1 hatch
- Camber....
- oem parts
- Compatibility: B20a Head and B20b/z head...Anybody?
- setting FPR
- Turbo questions.
- please help me
- ECU Question
- <<<<NEEDS EXHAUST for 91' Integrea GS
- Haha
- 92-95 tail light ??????
- header question??
- would 440 dsm inject be 2 much for ls/vtec 11:1
- Engine Swapping Easy!?
- Good Automotive Paint Shops
- HP Capabilities
- brake installation
- Will a b16a2 piston fit in Ls Block...
- Adjusting cam gears
- getting board with the civic...
- 5th Gen civic w/B18c owners
- New Motor Almost Broke In And.....
- Katmans car...PHOTOS!!!
- attn: mrselfdestruct
- CRX dual exhaust?
- Good Shop To Buy And Intall A Swap
- need timing adjusted and a few minor things.(TAMPA)
- Interior questions?
- Turbo Oil Line Fittings
- Just about done
- Alternator/Power Charge Question
- Timming belt question?
- automotive engineering
- d series tranny numbers
- no compression??
- A/C question
- Can someone do me a favour: Turbo timer!
- some mini-me questions
- need mechanic who knows integras
- radiator question
- sure fire way to tell if tranny is bad.???????
- FINNALLY fixed wiring and car starts. BUT.....clutch prob
- which hondata do i need
- automatic and m/t jack shafts the same?
- HONDATA
- Grinding question
- Motor swap!
- Cams?
- Exhaust wont fit??? gsr motor in 96 civic coupe
- 88-91 lude glass sunroof in a 88-91 CRX?
- Exhaust?
- Which Crank?
- AC Bracket off Del Sol B16???
- Seat belt Question...
- Refreshing old motor questions
- Cluster Install
- Type R cam comparison
- CRX Fuel problems
- Engine Swap question
- LS/VTEC IN 88 H/B WHAT HARNESS IS EASIEST????????
- which shocks?
- running rich
- Upgrading Brake System...
- custom exaust work?
- Best Almost Stock Looking exhaust ??
- Difference between Rota And Spoon SW388
- Timing adjustment
- Fire coming out of exhaust
- cooling problem solved...i think
- who has rsx here
- bgger injectors......
- Skunk2?
- EXCLUSIVE! Spy Shots Project "Windchaser"
- 86 prelude
- CV joints....need help/location
- Need help badly
- del sol rear discs
- Cat Question
- need help quick...
- need help quick....
- 3rd gen lude question
- need front lip spoiler painted where to go?
- honda header dyno tests?
- Can Honda head bolts be reused?
- Where to get Drag turbo?
- Floor board
- headlight problem
- Engine Problem
- d series engine/transmission
- honda radio
- special tool for vavle adjustment????
- will this work
- what can you do to a 89 si engine?
- I need a new engine suggestions?
- PCV valve it there an easy way?
- putting pistons into my h22
- My opinions on Testpipe
- good place to get a install
- LS tranny in turbo b16?
- Good Speed Shop
- What turbo for my GSR???
- Front bumper question...
- Which one would work better....
- ? about header
- Engine Code Question?
- pros and cons
