coolant leak
Old Oct 15, 2005 | 12:05 PM
nismo180's Avatar
Default coolant leak
I recently bought a 94 inegra ls and it is the first honda i have owned and i noticed the other day that it has developed a coolant leak cooming from the back of the motor. i don't really know where all of the coolant lines are on it and i was wondering if anybody had any diagrams of the lines
Old Oct 15, 2005 | 12:16 PM
freakasis's Avatar
back of the engine? or the back of the engine bay? be more specific and i could prolly tell you the problem.
Old Oct 15, 2005 | 01:17 PM
nismo180's Avatar
sorry about that, back of the engine bay
Old Oct 15, 2005 | 01:41 PM
freakasis's Avatar
if its comming off the firewall its one of lines that go to the heater core.
Old Oct 15, 2005 | 01:49 PM
nismo180's Avatar
thanks i'll check it out
Old Oct 15, 2005 | 02:18 PM
TSX24L's Avatar
could be the water pipe on the back of the block that goes into the water pump and thermostat. There are two o rings that in time will need to be replaced. Easy to fix. The best way to find out is to pressure test the system. Get a pressure tester.
Old Oct 15, 2005 | 03:55 PM
DA92driver's Avatar
also, check the hose from the back of the intake manifold , it goes to the back of the bay as well it happend to me about a week ago. should go into the iacv or fast idle valve on the backside of the manifold, near the TB. hope it helps goodluck
