View Full Version : Honda/Acura Tech
- Priceless
- right hand drive?
- flywheel question
- y8 head z6 block torque specs
- i thought honda's were reliable?
- Wastegate/ radiator wtf
- weird idle
- If you have a 02-03 Si please read this
- Which Honda Dealer has the lowest prices??
- Manual Conversion
- ***JDM Civic (Right Side Drive) Front Clip Into a Standard Civic Front Clip?***
- Turbo Exhaust Sizing
- axle
- Bolt snaped..
- homemade turbo kit questions
- car hesitating
- Auto to Maunal swap 93 Civic
- whats the D16Z6/Turbo full setup?
- piston to valve clearance H22?
- New tranny is in!
- knock sensor
- Best street tires??????????????
- engine codes
- Hondata question
- B16B Pistons
- eclipse injectors on a 88crx si?????
- DIY free mods?
- No Front Turn Signals
- problem strating up. help
- Integra 4-2-1...4-1??
- Acura Question...
- anyoe know anything about alarms??
- Pullies
- engine bogging down in 5th
- Best Parts for a LS.
- TECH: Car Math e/t, weight, 1/4, 1/8
- Thoughts on CTR/ITR cams???
- Need Help Tranny ??????
- Having Trouble Finding Wiring Harness?
- Wheels bearings
- new best 1/4 mile time
- H/A Track Meet at BMP
- what swap should i go with?
- what should i do next?
- rotors
- 250 lb/ft torque..easily obtainable?
- who makes good b18b1 ls cams?
- Bay City Clutch
- Head..
- b18a,b18b the difference is????
- blown engine???
- Cleanin Injectors.................help???
- Endyne problems..
- My ghetto HMT Sohc un-mini-me civic *pics*
- 96 hatch, LS mounts help
- learning
- Update on my project...
- idle problems
- Next Setup Suggestions
- std hubs,si hubs diffrence?? same??
- mini me or z6block question? opinions.
- owners of 88-91 hatch/rex-Fuel Pump question
- LS/VTEC Turbo??????
- Leak and Body Shop
- wich b16 t/b dosent have map sensor mounted?
- Golden Eagle HD Series block build up *pics*
- cooling fans
- boost question
- ECU chips?
- 91 si / b16a injector same?
- !!!!LINK to Blue Weave CF hood F/S!!!!
- problem
- Need help with seats
- o2 sensor help..
- honda/acura
- Civic will not START what is wrong??
- Import/Domestic performance new shop
- Bouncing Idle
- TECH: D Series Cylinder Head Tips
- hybrid axles
- *********attention************
- axel problem
- lost motion assembly stuck?
- Diffrences in crx si and 2g teg lca's
- TPS adjust.. Need someone..
- Open CHallenge
- timing belt broke what to do
- upgrading to bigger intake...
- turbo s2000 dunebuggy
- idle is high help
- how do i know wich b16a it is?
- Horrible Smoke
- price to install lsd
- DX cold air intake
- jdm lsd vs phantom grip
- Type R LSD???
- help
- Good head to start with?
- will a ls turbomanifold fit a gsr
- 2.25" gasket...
- exhaust ?
- Can anyone recommend a good Honda shop?
- to boost or not to boost that is the question
- 96 teg,01 type r bumper, ? WHAT FENDERS ?
- What gagug wire..
- H22a ('96 SI Prelude) Swap to 2gn Teg??
- help with cam?
- What Type Of Engine Management?
- Precision SC50, what A/R?
- 2 Codes, and a partridge in a pear tree
- for you hybrid boys
- Mini Me swap?
- stuttering b16a obd0
- What kind of turbo
- 2nd o2 b16a
- Location for the Next meet............
- can b17 handle 10lbs and 125 shot???
- :? still leaking afte new distributor?
- TECH: Horsepower... Making it add up.
- I need help
- 2.1l B18c
- How to view code for check engine light. 96 accord
- quick question...
- vx cluster into a cx turn signals problem
- resleeving costs???
- Oil leaking from the dizzy cap? Help
- anyone know best place for assembled shortblock??
- tranny question
- repairing header
- block girdle?
- Inside a cluster
- Integra Meet 3/13/04 at IOA
- finally got my honda project started - 56k warning.
- delete
- Engine Harness Question
- GSR Swap ?
- goofy tachometer
- gsr rods
- WHO does balencing&blueprinting of pistons?
- 01 gsr seats in 96 civic coupe
- Accords Auto transimssion- 3rd and 4th died
- fuel rail swapping...please look
- pwr steering 90 Accord / H22A
- Compression Test Results
- TDC sensor error...
- Budget turbo for sohc
- CRV Turbo in a Street CRX
- gauge, knock sensor, transmission issues
- not shifting right
- Exhaust Question?????????
- turbo for my teg - have a ? - need help
- B16B swap issues
- rebuilding a b18a1
- integra head swap
- thanks to all...
- what do you think it is
- ATT: VAPOR CRVTEC Q's
- Went to the home of the 719hp Civic!!!
- vss wiring info b16
- traction????
- engine
- Air Intake Filter Shoot Out.
- Integra RADIATOR support?
- obd 0 vtec b16
- 1.5 cx vs 1.6 z6
- Block rebuild???????
- Official Roll Call and Stuff to Bring for H/A meet (sticky)
- vtec doesnt engage all the time. .
- f22a to h22a
- injector help
- i might be joining the darkside!
- leanin out badly
- What should I do ?
- what kind of cam is this?
- gas tank on 92 cx hatch
- cam tuning
- ..........uberdata..........
- Honda does go into park, reverse or Neutral
- grrrrr wtf!!!! @$%#^&!
- engine ?
- brake light??? please help
- hondata shiftlight
- I need My new Ctr pistons to fit my Hbeams Kj?
- good place for camber kit install and alignment shop?
- 92-95 Civic Si/EX what gives ?
- skunk2 stage 2's
- Engine Codes, HP, Chasis, Year, Head casting #'s
- VTEC Solenoid clean-out
- 88 crx fuel pump
- Ex V.s. Si
- 88 prelude 2.0
- Interior color?
- Engine BreakDown By years 81-04
- help
- Fuel pump..
- Conn. Rod Strength
- whats the best tranny to use?
- will auto ecu work in manual car?
- Synchros
- Del Sol Headlights
- engine swap
- Sorry to let the Honda Camp down!
- tranny question..turbo related
- Att. Crix
- crx si head on a d15b7
- Motor Swap Q's
- So Bored
- H&R Sport Springs and Tokico Blues...
- D15Z1 what is it
- Show and Shine
- Civic turn signal
- hey anybody got the blue badge
- Motor turns on then turns off
- i have a question about my Honda
- Broken Bolt removal tips
- car prob
- ABS Light
- battery light comes on
- *Need a valve adjustment, timing belt, and cv joint replacement.*
- Strange whining sound outta 1st & 2nd gear????
- Motor sputters?
- lifetime coverage on seatbelts?
- white smoke
- Injector question
- simple question
- Will I snap an axle if.......
- my EK on radials, back to stock
- 1st generation CRX question
- slicks test fit on my EG
- need suspension info
- need advice building turbo b16
- a/c with b18b in 94 civic
- i need help pleeez
- turbo kit for a swapped hatch?
- where do i get a crx windshield
- SOHC V-Tech question ?????????
- Fuel Pumps.....Difference?
- head gasket
- !!!o2 Simulator Question!!!
- Rod bearings, help please
- Will I have to much lag?
- cv joints HELP!!!!!!!!!!
- engine surge, but not idle air.....
- camber kit install
- motor shops
- Custom Turbo List
- Local turbo shops
- My Ferrari and SL55
- valve noise help!!!!
