- Best Gas Place?
- Question about Camber Kit
- MY car
- axel fucking wont go in or bad grommet maybe?
- is this possible?
- Attn. Car Theft Alert!!!!!
- how does your car run
- Lst Or Lsvtec?
- !!!oil leaking through intake manifold!!!
- Coilovers
- looking for a site
- the challenge
- impossible question none can answer
- how to tell the diffrence...
- quick question
- quick swap ???
- Cf Hood
- HP for h23a
- Over heating...
- Clutch feels like mush.
- honda firing order
- power steering help
- Timing Problems
- electrical problem?
- quick b16 question
- New Honda site...
- Electrical Problem
- leaking hatch
- timing
- Phantom Grip
- headers
- dis. question
- *** Quick -Zex- Install Question ***
- Can this be fixed
- I Have A Problem
- SI to D16z6 SWAP Wiring harness?????
- s4o tranny???
- Which B series motors respond best to mods?
- Vin # on Block??
- Timing.
- type r honda
- E-ram?
- is it worth it
- 4g Suspension
- 2000 Civic si coupe vs. 2002 Civic si hatch
- dyno hp tq?
- Whats a good swap HELP
- Adjusting Projector Headlights
- I need help badly...
- whick way to go
- Im impressed i must admit *video*
- need help with install
- LS Turbo Parts List Q's
- i need some tech help
- need help if you can
- head work on 92 accord h22 head swap
- temp gauge install
- Any H22A Owners out there....
- anyone chipped thier ECU ?????
- Need B16a Throttle Cable Asap
- B18c4
- 91 Prelude Swap?
- My dyno
- Offical B vs D series Thread
- B16A3 Dyno Results
- radiator fan help
- DX knock Sensor ?
- pic request
- flush mounting the Si lip
- threw the EVAP code, need help
- valves
- How safe is this ?
- '00 GS-R sedan: very low ride height, mud flaps scraping
- d16z6 tod15b2
- tranny swap???
- for all those d-series ppl
- 165 whp ls all motor poss?
- a nice thread about exhausts and shit
- GSR head tech ???s
- pulley kit??
- anyone know the sn Patrick? i need info
- cam gears
- quick question on clearance.
- Head Gasket
- will these springs work? please look
- r pistons on ls rods
- You probably heard this 1000 times but PLEASE help
- another question about steering rack..
- how to smoke taillights??? any1???
- Quick Question
- CRX Climate Control
- head spring question
- Idle problems...
- daytona tunerbash march 21-22
- help settle a debate
- knock sensor?
- HX to EX
- a/c install
- Ecu ?
- good sounding Exhaust
- JE Pistons, proper honing and ring seatment...
- Shop for boring?
- ? about shot peaning
- Import builders?
- Tie rod ends..
- Auto to Manual
- Need help wiring VTEC
- For all non_believer of the stock SOHC 11sec pass
- Rear bars..
- Koni Red's
- b16a or ls swap needed for hatch si
- Cv Shaft Help Asap!!!
- skunk2 intake mani on GSR which intake??
- Broken bolt...
- pr3 mugen chip
- Apexi VAFC Controller Setup
- Anyone familiar with...
- Quick Question
- Swapping a DX head with an EX head..worth the trouble ?
- Suspension problems
- Tap Manifold?
- Who will fix my problem, hmmm?
- can this set up work??
- canadian LS ?
- WTF is a P2K??
- oil pressure gauge...
- h22 ecu question
- Lets play, Name That Seal
- Differences with b18a/b
- Compression Question?
- Ecu
- A yes or no question.........
- More power from a single cam!!!!How???
- D series block tech questions
- How to redo civic hatch mirrors????
- WTB: crx fenders
- B20A Main cam bearing cap torque spec?
- POLL Colin or Neil
- throttle cable bracket ??s
- H&R springs?
- how do you adjust the throttle on a b18c1
- question about b17 head
- Seriously Need B16a Swap Done Help
- HX tires on SI wheels?
- Engine light came on......
- Syncros
- anyone know stock fuel pressure
- P2E Ecu??????????????
- Out with the old....
- Ecu Codes
- After Market Sterring Wheel on Accord '97 Problems
- Need help with seats..
- acura type r
- got a JDM B16A VTEC ENGINE
- zc
- wire digram
- gauges
- Apex Vtec Controller
- Hondata questions!!!
- Auto B16
- JDM B16a...
- It never ends
- Which tires hold up the best?
- any shop around here
- Will this work?
- H22 crx swap ?
- P2E Ecu came out of what?
- damned IACV
- b16 tranny tech
- fields VTEC question
- *Need help to find Ecu 90-91 Crx Si PM6-A09,A06*
- Mini-me Swapping????
- brand new turbo cheap
- How much would u pay?
- times for 96-up hatch
- B16a, std/dx to B16 wiring harness
- trannt and gauges
- lsvtec
- whats
- ?? d16y7/8 in a 89 rexSi.....Comments welcome!!
- LS VTEC question
- Hybrid...
- Radiator
- Vafc
- ?cracked Headers?
- New synchros
- running rich
- Phantom Grip
- track time for an 90 ls
- 11:1+boost?
- Please Help with Steering
- Block questions.
- Cheaper?: GSR Seats vs Reupholster
- radiator problems
- emblems
- crx harness
- Crx ECU Question
- 2 questions.
- need help bad
- Code 34 Help!?
- Jim Fab
- Auto>>Manual
- Help
- place to mount vafc??
- crankshaft postion sensor
- how much HP would............
- B20 crank and special mods needed?
- JDM B20 Question
- problem with h22a
- header for b16
- quick tire question(opinions)
- any homemade Bseries manifolds??
- Brake question fo ya.......
- OBD2 LS into 92 CX using a P09 engine harness--Assistance Appreciated
- turbo dseries?? or jdmb16??
- Fields vtec controller install....
- Compression Numbers/ Leak Down?
- Buyer beware
- radiator hoses
- LS wiring in CRX HELPPP
- B18a crx wiring HELP!
- Alternator Belt??????????
- '92 Civic Overheating - Blown Head Gasket? Experts HELP!
- CRX Glove Box=HB Glove Box?!!?
- tie rods ends..
- after market gauges
- Fuel Help .........
- Need HELP!Crx Si Oversized Valves
- vtec gasket selection....?
- Ill Pay, Someone Take Out My Dash
- itr tranny
- Need Parts For 1990 Acura Legend 2dr
- I need ideas for my zc
- LS BLOCK Questions
- OK-trying this again...with a pic...PLease help
- what supen................??
- 94 Integra LS auto-to-manual tranny swap
- full throttle
- headers
- intake manifold
- please help major problems
- I need a cam NOW but which one??
- ls swap
- 90-91 CIVIC Rear disc brakes?
- Best Car Alarm
- Best tranny for an LS motor ?
- Tranny Swap Question
- tricking OBD2 O2 senser
- A few problems
