- Peete how is the teg coming?
- tech guys got a questin for you
- clutch problem
- Which is the better bottom in autumn........
- Injectors
- Well, I'm fuct
- waterpump help
- Tachometer Wire?
- Need good import performance shop
- wobbling steering wheel
- need help asap with wiring
- Bradenton 9-14
- Ls/Vtec opinons and help
- For the SOHC fans.
- It's official, i'm going turbo....
- thanks to secret services
- anyone have intake tubing??
- looking for camber kit for 92 prelude
- Solenoid ?
- ignition timing
- b18b1 or b18c1
- Car wont start fuel/electrical problems???
- 1st gen CRX back seat???
- H22a into 5th gen Accord
- LOOK vx civic?or ex
- Stock pipe size?
- Another b20 vtec question
- CRV-tec questions
- KONI REDS (Any good)?
- Door trim needed
- honda's not starting.
- Help!!!1
- Please Help!!!!!!
- Car Wont Fire Up
- Oilpan Needed Asap!!!
- b18c1 into 97 dx
- Crank identify..
- head changes
- B18c1 into a 1990 CRX
- Reminder: Hondata DOES do nitrous control
- Tech: Cleaning up the oil
- Camber problems
- crx question HELP!!!!!!!!
- will these swap bars fit
- lsvtec questions..
- badass rex
- question
- ignition switch on crx
- Interchanging Civic Seats
- Good place to buy an Engine?
- HONDATA Questions
- Injector question????
- BACKFIRE good or bad?
- interchangeable parts on crx/civic hb
- prob with 92 cx hatch
- rack and pinion on teg
- Custom mid piping needed
- Dyno: Hondata VS. Stock
- b18c5 engine needed
- trunk latch
- My swap!!!!!!!
- shot pend..
- oil burning
- GSR Intake Manifold
- Slicks and LSD?
- Engine Identification?
- I need a phone number for ACE......
- this is a pic request
- phantom grip
- JDM .25 ITR Pistons
- Clarification.
- turbo oil pressure problem need help fast!
- Question: Acura supercharger
- Help me out please
- need help car won't start
- Can I please get some help, much appreciated
- < Track Day #5 Make-up Date Is All Set >
- places to turn a crank
- *prelude Meet~gainesville*
- 94 lude speedometer gear question..
- Dyno: Bosch VS. NGK
- auto manual conversion
- Where to find a B18b1 Motor in Tampa??
- What do i need to make a b16a1 fit in a del sol?
- My rods
- anyone have a MPFI D15 or D16???
- crank question
- Vtec Question
- engine block etc..
- B series mount????
- swapping my teg
- Gator Racing Axles
- crank pulley & timing belt gear....how many keys?
- Intercooler Piping blows off!
- Are you currently happy with your Honda?
- swap help please (tranny!!)
- problems in the world of crx
- Not tech related but definitly forum related...
- will it hurt my engine to run it with open downpipe?
- V-tech problem
- Spark Plugs wires
- Re-wiring brake lights
- Upcoming Gainesville Prelude Meet
- Air Conditioning Not Working
- GSR cams in a B16a1
- TECH: some gear ratio questions answered
- TECH: Performance Specifications of Production Cars
- TECH: LS/VTEC review
- TECH: checking the ECU codes
- TECH: resetting the ecu
- Gsr Ecu
- Gandy's Shell meet
- car got broken into!!!
- where to buy
- smallest tires for 15 in rims?
- MSD SCI-L Installation
- Profec E01 and Emanage Install in GSR
- New Head Gasket....
- My hub bearings are fucked!!!
- TECH: Piston deburring
- little wiring help
- jdm itr header reworked
- help!!!
- Can anyone here tell which point on the VTEC.......
- Crower Valvesprings and Titanium Retainers Review
- Motor Build Up!
- Need Radiator Fan for '94 Integra LS
- can u boost a car with a code 7
- TECH: B16a? How to tell.
- Civic Meet Pics (56k WARNING!!)
- Can someone give me a pic of their MAIN RELAY?
- Rate this thread/Report post.
- civic meet review
- honda trouble codes
- Tranny question
- Car loses power after it warms up!
- valvetrain
- need someone to install valvetrain and cams
- Anyone With A 5th Gen Prelude- Supercharged
- BeadBlasting?
- which wire on the O2 for the gauge
- Uh oh...Need Help quick
- RSX-S swap
- single cam internals question
- 88-91 HB-CRX Wiper Hand Travel...
- ECU Question
- Dumb Question......
- Clutch Install
- TECH: Keepin that paint shiny and new.
- 93civic seat swap
- Clearwater turbo H's
- noise at 3k?
- ### Exhaust Question ###
- looking for turbo adapter plates for d16
- Im callin a Meet!
- Im callin a Meet!
- Welcome our newest H/A mod
- integra seats in my car?
- TECH: D series piston comparison
- Like to say thanks
- Is an H22 swap a bad idea for a 93 del sol??
- wheel studs
- For Fuck Sake!!!!!!distributer Help!!!!i Need One!!!
- reseting the maintance required light....
- Stroked Motor Build Up
- will this work.
- HELP! throwing code 17???
- Good Deal
- TECH: GSR ECU on an H22a!?
- Civic Meetup Sign Up Sheet
- Pre- Florida CRX meet in tampa
- Blew up the B16 tonight. . .
- Air/ENDYN Intake Manifold
- Integra Meet : Aug 24
- Honda/Acura FAQ - Please Review This Before Making A Post!
- lug pattern on prelude?
- spray on stock internals??
- valve specs
- help me with my integra question:
- Best Head Gasket for Boosted Honda
- TECH: Collection of Specs
- TECH: Acura concept TL
- Hondata
- Civic Type R LSD fit in to a S1 cable tranny?
- knock sensor
- doing swap need help asap><
- Gsr head gasket ???
- Integra 91 with 18'' rims
- My new project
- distributor
- Effects of Port and Polish
- Honda Accord Needs Help
- price of honda brake fluid
- are headers worth their price?
- Shift Linkage
- can a SOHC/turbo make 300hp?
- weight of ls transmission?
- 200,000 miles!
- TECH: Main relay replacment
- turbo or no?
- LS/VTEC question
- need help with oil return????
- Why don't people really help
- oil leak
- Looking for more Speed
- Check engine light codes
- integra misfire
- I think i was chipped, ECU problem need help
- H22A crx swap..
- Coil?
- !!! Please Help !!! Cyp Sensor
- o2 pinout on 99si for air/fuel gauge??
- Need Some Suggestions For A Reputable Shop!!
- Please help me!
- ITR rods, CTR pistons, B17
- storage
- Help!!!!
- Myth of Fact ?
- Si brakes
- crank diffrence?? b16 vs type r
- In Need of a B series swap
- Help?
- Help Needed!!!!
- ?? Oil Pan Swap ??
- Blocks strpped....
- Civic Meet on Saturday Night
- My nice blue Ep
- swaping pumps...
- TECH: Swap Nightmare....
- What's Next ???
- opinion plz!!!!!!
- rsx type s seats into an ef hatch
- 440 RC injectors too big??
- VAFC question, fuel mapping??
- radiator change
- Civic Carbon Hatch??
- I need some help
- Any one knows how to fit a H22A?
- Trunk Release
- Tranny Problems
- !?!?!?ECU swap in a Civic!?!?!?
- Turbo
- gsr question-read
- TECH: Preventive Maintenance
- TECH: EM chassis, Torque converter... no longer are auto's lame!
- Money to spend!
- 4 lug to 5 lug adapters?
- ????car Wont Start????
- Honda Issues...
- Cant Decide- 1.8 - Bore out and resleeve to a 2.0 or just Hone
