Coil?
Old Aug 9, 2003 | 05:12 PM
Vito_Corleone's Avatar
TR Balla Donor Supreme
Default Coil?
What coil do i need for an 89 b16a preOBD?
Old Aug 9, 2003 | 06:11 PM
kender's Avatar
gadget man
msd blaster ss and the modified cap, both can be found for less than $100 total by surfing the net, takes about an hour to install and worth every penny.
U.S.S.A Crew Member #001
Old Aug 10, 2003 | 06:36 AM
i meant stock i just need to know what engine to get one for i.e. 99 si, 92 gsr i just need to know if it needs to be obd0 or if it matters at all but thank you for trying to help
Old Aug 10, 2003 | 06:54 AM
kender's Avatar
gadget man
no prob. I have the same swap in an 88 crx si and the first thing I did when I got it home was to chuck the stock coil cause its week. But check the pricing on the stock one and if you can upgrade for a little more I would. but for a stock one I don't think it has to be obd matching as its not a sensor its just basically a step up transformer for your spark plugs.
Old Aug 10, 2003 | 09:09 AM
Thanks man i'll look into the msd.
Old Aug 10, 2003 | 01:08 PM
NChatch's Avatar
i stepped on my weiner!
any dohc coil should work....on my obd-0 motor, i kept frying distributors with a 6AL and an external coil......have no idea why though,
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Aug 10, 2003 | 05:51 PM
KJ's Avatar
KJ
bored at work
You can use the coil off of any obd0 distributor. 90-91 LS, 88-91 si/hf, 88-91dx, whatever. All obd0 ignitors are also interchangeable.
Old Aug 11, 2003 | 07:35 AM
letsrollagn's Avatar
BRT OVERKILL
actually they all work (i.e.,b16a2 distributor on my 93hb, or the 00 si coil on my old rex etc, non-obd coil in deboes 93 prelude...etc, etc...)...coil does not matter as long as it is working, but the icm chips are slightly different...course I have swapped those out as well, gen. just pertains to the way the bolts hold the chips in place...if you need one, I have a bunch
Why is it when ever I really need to weld something the acetylene always seems to run out...
Only babies drink from bottles...
Boosted 00 Si
N/A 93 HB b16/18
