Car wont start fuel/electrical problems???
Old Aug 27, 2003 | 06:16 PM
Spence's Avatar
"TEAM WHITEY"
Default Car wont start fuel/electrical problems???
Well today i was trying to wire in a fuel pump kill switch through a relay. So when i got it all hooked up it did not work the pump was not cutting off when the switch was hit. So i said fuck it and was going to hook the pump back up and get some eletrican to do this shit. When i hooked it up the fuel pump did not turn on and it just cranked but no start. So i went to the yard and pulled a fuel pump installed it but it did not work. Still no sound of the pump. What could be wrong the main relay? or What
Thanks for the help
_______
REPRESENTING PORTLAND OREGON THE WEST COAST TR MEMBER
Old Aug 27, 2003 | 08:47 PM
Si-R Trickey's Avatar
The most interesting man
Sounds like the main relay to me.
Old Aug 28, 2003 | 04:17 AM
Spence's Avatar
"TEAM WHITEY"
which fuses? i was told the main relay is the fuse for the fuel pump
Old Aug 28, 2003 | 04:38 AM
Durdan's Avatar
No Ants Drift Member
heres the deal. remove the switch. put everything back to stock. take your fuel pump and just hook it up to your car battery for a second to ensure its still good. now. make sure everything is back to stock. turn the car on. does the pump come on? if so, lets get to work.
take the ground wire that the pump and put a toggle switch in that. a toggle switch is an open/close switch. if you open the curcuit in the ground, the pump is no longer grounded and hence wont work. when you close the curcuit, the pump will work and you wont burn up the switch with amperage. its just that easy.
RIP Tim. i miss you, buddy
Old Aug 28, 2003 | 07:15 PM
Spence's Avatar
"TEAM WHITEY"
anyone want to lend a hand on sat after 6?
Old Aug 29, 2003 | 05:25 PM
Spence's Avatar
"TEAM WHITEY"
so here is the update the fuel pump is good we checked it with the battery the relay is good we used the one off my buddys eg hatch car still did not start tommorow we are going to install a stock ecu and see what the deal is
any other help we be appreciated!!!!!
Old Aug 29, 2003 | 06:54 PM
Joe's Avatar
Joe
Sodalime is good.
Volt Meter time....
Make sure that the 'hack job' you did didnt mess up the power source...
If you DO have voltage then you need to verify that the ground is connected properly.
Turn the key and whalla... it should now work...
Joe
Originally Posted by President Abraham Lincoln
America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.
Socialized Medicine?
Originally Posted by a former president of the US
One of the traditional methods of imposing statism or socialism on a people has been by way of medicine. It's very easy to disguise a medical program as a humanitarian project.
Old Aug 29, 2003 | 08:06 PM
getrdun's Avatar
"Lucky"
What ground? Everything appears to be fine. The only piece not responding to the volt meter was the Main Relay, but we changed that by switching the one from my car, and it still did not work. He thinks it might have fried the ECU, is this possible? I think something is grounding out, or somewhere in the 'hack job' of wiring on his motor swap, a wire got disconnected. Who wants to help? I am a electrical retard. Shit, I just got a good mental image of that. LOL
"Thou shall not weave in and out of traffic." -The 11th Demandment
