integra misfire
Old Aug 10, 2003 | 11:36 AM
96tegra's Avatar
Default integra misfire
my car is misfiring its not the plugs or ignition. injector bad????? help me please
Old Aug 10, 2003 | 12:01 PM
mtber's Avatar
Is it throwing any codes ?
If it is diagnose the codes then go from there.
I would check your ignition again.. including your ignition coil.
I would also check for a short around your ecu plugs... jiggle them around and make sure they are plugged in correctly.
Old Aug 10, 2003 | 12:31 PM
Josh's Avatar
Dr. Doom
also check for precipitation down in the spark plug hole, pull the plug boot out of the holes and let it dry out.
Old Aug 10, 2003 | 02:35 PM
TRD_Tc's Avatar
Using The Force Of N/A
You might want to look at the distributor.
Old Aug 10, 2003 | 03:52 PM
96tegra's Avatar
i found out what it was.
thanks guys
Old Aug 10, 2003 | 04:40 PM
mtber's Avatar
it would be cool if you told us what it was..
or wait was it something so stupid it is embarasing :-?
