reseting the maintance required light....
Guest
Posts: n/a
The Maintenance Required light comes on at factory predetermined milage intervals. If this light has illuminated, there's nothing to to be worried about. It just means that the car is telling you that it is time for a scheduled service of some kind.
Usually when you take your car in to have a shop service it, they will reset the maintenance light for you, however sometimes you'd like to do the work yourself and get rid of that flashing light on your own.
The process is really easy, when you're sitting in the driver seat reach down with your right hand underneath the dash about where your right knee would be. Tucked underneath the dash panel you will feel a small black box about 3"x3" with a small square button in the middle of it, facing down. All you need to do, is press the button down and while holding it down, turn the ignition key from:
OFF -> ON -> OFF -> Start the car -> Release button
That's all there is to it! The Maintenance Required light should now be dimmed until the next time you reach another scheduled service milage.
I never knew how to get that thing off. Thanks.
Gracie Barra Clearwater
Originally Posted by Cronic
My civic just had a hole for the key to fit in. It wasn't a light however. Great info though Hartman.
cronic where the hell have you been????????????????????
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
i think in odb2 civics, there is just a green square on the bottom of the cluster, that will eventually turn red. to get it back to green, just stick your key into the slot next to it.
I <3 RooR!!!!!!
I <3 RooR!!!!!!
