Motor Build Up!
Old Aug 18, 2003 | 12:57 PM
Crab Cakes's Avatar
So Lost!
Arrow Motor Build Up!
I am going to start building a turbo B-series motor...I am not sure which motor setup to run though..Either a B18a/b or B16a2 or a B18c1... My power goal is 400whp..
As the tranny wise. I want to go with a gsr tranny.. I have heard that the ls tranny has too long of gears for boost and the si tranny has the shortest gears good for all motor wise..Is there anyhing that needs to be done to the tranny like limited slip etc....?
For the block I am going to get it Golden Eagle Sleeved with pistons and rods..Should I use Eagle, Crower, Pauter etc rods??
For pistons should I use Je or Wiseco etc?? What else needs to be done to the block to handle this hp??
For the head, from what I have heard the it does not need to be build up..Is this true, if not What needs to be done??I am going to run a JG Edlebrock or Skunk2 Intake manifold...Also what kind of fuel do I need to run..I am going to be running Hondata..The turbo will be a turbonetics t3-t4 with a 60-1, How much hp can that put out......Let me know whatever I need to know...
Thanks, George
Im The Original Crab!
Old Aug 18, 2003 | 01:56 PM
99B16Si's Avatar
B18C1 sleeved to 84mm
Eagle Rods (no point on spending double on crowers)
endyn pistons
Gsr tranny w/ quaiffe LSD
at least 660cc injectors
high flow fuel pump
a t3/t4e with a 60-1 and a stage 5 wheel in a .63a/r housing will be good to at least 450whp, over 500whp with an .82 a/r. but if your looking to make some serious power go with a garrett ballistic ball bearing/or precision turbo.
Old Aug 18, 2003 | 02:12 PM
99B16Si's Avatar
why u say 81 and not 84mm???
and what do u have against eagle rods and 400whp?
Old Aug 18, 2003 | 02:15 PM
Crab Cakes's Avatar
So Lost!
What is the difference?? 81mm to 84mm?
Old Aug 18, 2003 | 02:16 PM
99B16Si's Avatar
1.8L vs. 2.0L
Old Aug 18, 2003 | 02:17 PM
Crab Cakes's Avatar
So Lost!
What motor should I build?
B18a/b, B16a2 or B18c1??
Old Aug 18, 2003 | 02:19 PM
99B16Si's Avatar
a b18c would be the best but is by far the most expensive
Old Aug 18, 2003 | 02:21 PM
Crab Cakes's Avatar
So Lost!
I was thinking of the gsr my self..I like that motor better than the other two..
Old Aug 18, 2003 | 02:23 PM
99B16Si's Avatar
or get a b16, build the head also, and rev the piss out of it
