????car Wont Start????
Old Aug 6, 2003 | 04:48 PM
MOORESPEED12's Avatar
BRING IT!!!
Default ????car Wont Start????
I have a 91 crx si. I just installed an LS motor in it. I had the motor swap in my hatch but now put it in a rex. The problem is when I turn the key I hear a click that sounds like a relay and its right behind the dash behind the radio. If I jump the starter with a screw driver it will turn over. What would cause it not to turn over by the key? PLEASE HELP!!!!
Old Aug 6, 2003 | 05:16 PM
EG6's Avatar
EG6
Check to see if you are geting a signal to the starter when you turn the key. If not then you need to replace the ignition wire(The picture shows what IM talking about). If thats not the problem then trace the wire to the fuse box and see if your getting current on the other side your problem should lie there. The same thing happened to me ill post a pic of how i fix it soon.
Old Aug 6, 2003 | 05:17 PM
EG6's Avatar
EG6
Old Aug 6, 2003 | 05:51 PM
BRING IT!!!
I will check it first thing tom. Thanks EG6
-Tony Moore (Moorespeed12@yahoo.com)
Old Aug 6, 2003 | 06:25 PM
4drhybrid's Avatar
i hate you
check all your grounds
You cant Bullshit a Bullshitter
Old Aug 7, 2003 | 01:04 AM
Durdan's Avatar
No Ants Drift Member
clutch switch - bypass it
dont go tearing about your column
next try it if not, call me
727-571-1450
RIP Tim. i miss you, buddy
Old Aug 7, 2003 | 02:39 AM
Crab Cakes's Avatar
So Lost!
Damn that sucks for you Tony...I want to see the car when it starts...
Im The Original Crab!
Old Aug 7, 2003 | 11:50 AM
BRING IT!!!
Found the problem. It was the CLUTCH SWITCH !!
Thanks Guys
