ITR rods, CTR pistons, B17
Old Aug 9, 2003 | 10:13 AM
TEP-ITR-REX's Avatar
Default ITR rods, CTR pistons, B17
If a b17 has the same deck height as a b16, has anyone ever used ITR rods in a b16, I have .25over CTR pistons, Im wondering if its gonna hit and if not will compression be to high? Using an ITR complete head. Thanks
I drive a HONDA so what!! My GF is BANGIN must be the MOTOR...
Old Aug 9, 2003 | 02:44 PM
NChatch's Avatar
i stepped on my weiner!
i dont think you can use itr rods in a b17, i thought they were a unique rotating assembly of thier own
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Aug 10, 2003 | 08:01 AM
Ive been on c-speed, it wont let you switch rods. just complete botom end..
Old Aug 11, 2003 | 04:26 PM
gotvtec20's Avatar
Import Tuner
you cant use the 1.8 itr rods in the 1.7 si block. it is the same height as the b16a and the same bore as all the b series blocks except for the crv but the key difference is the 81.4mm stroke as to 87.2 gsr/itr blocks. The rods would be too long for that block. You could howerver sleeve and overbore the piston size and make it a 1.8
03' BMW 330XI
Old Aug 12, 2003 | 05:11 AM
90b16crxsi's Avatar
Team Mullet
Thats what i thought i didnt know the exact mesurements, but i thought the strokes were different. I am having the block bored for the .25 oversized CTR pistons, so it will be a 1.8 do you think that will help alot. Also anyone want to buy ITR rods, Cheap Quick. I'll be posting them for sale. Thanks for the help.
Old Aug 12, 2003 | 05:15 AM
Ahhh roomates name.........again. sorry
Old Aug 12, 2003 | 06:22 AM
KJ's Avatar
KJ
bored at work
ITR rods won't work period. CTR pistons on the b17a rods will work. To get an estimate on the compression use the c-speed calculator and add about .3-.4 points to the compression (their numbers for ctr pistons are a bit low).
OEM oversized pistons are only .25mm bigger. This isn't much at all and displacement isn't effected a noticeable degree.
Old Aug 12, 2003 | 09:08 AM
Thanks, you guys know your shit..thats awsome I'm just getting started..
