crank pulley & timing belt gear....how many keys?
is there suppose to be one key for each the crank pulley and the oil/ timming belt gear? or just one long one on the type r motor? i have a new one from acura but it seems to be too short only enough to fit the crank pulley and not the timming belt gear...doesn't the timming belt gear have one too?
Originally posted by 99B16Si
theres 4 in the whole motor although some have slight variations in size.
1 for each camgear
1 for the crank pulley
1 for the timing gear
1 for each camgear
Zee
I work too damn Hard...
04 Civic Si
01 Lexus GS300
04 Civic Si
01 Lexus GS300
1 for each camgear
1 for each camgear
The timing gear uses the 2 guide plates...
Zee
04 Civic Si
01 Lexus GS300
04 Civic Si
01 Lexus GS300
Originally posted by Sunrise City Rider
Dude theres not KEY for the timing gear, the crank pulley and the cam pulleys thats all...
Zee
Zee
wow nobody knows the real deal on this......the timing gear has a groove cut out for the key then the guide plate then the crank pulley....so i assume that there are two keys one for the crank gear then one for the pulley....i hope that i'm right...the last motor i pulled had only one key...but this timimng gear does not already have its own key machined into it. who knows anymore
