V-tech problem
Old Aug 20, 2003 | 04:01 PM
RARE1NONLYCIVIC's Avatar
Default V-tech problem
ok when car starts up and gets warm V-tech works and as motor gets hot the V-tech will shut off ............. Can u help
Old Aug 20, 2003 | 04:03 PM
pressuredsol's Avatar
Pleasure the do me
What engine? How do you know if vtec is working or not?
BTW....VTEC not VTECH!
Old Aug 20, 2003 | 04:07 PM
MattC's Avatar
Professional Asshole
what motor, what ecu, check what codes your ecu is throwing, and describe whats happening
Semper Fi
Aim and Yahoo- Inkedupordie
Old Aug 20, 2003 | 04:08 PM
B16a only code is o2 sensor
Old Aug 20, 2003 | 04:09 PM
Josh's Avatar
Dr. Doom
Default Re: V-tech problem
VTEC is designed to operate within a specific temperature range. if you're oil is too hot or too cold, VTEC will not engage. you may want to check oil level, VTEC filter, Solenoid, ECU codes....blah blah blah.
Old Aug 20, 2003 | 04:10 PM
when first start up car I let warm up and drive it and then V-tech will kick in around 4500rpm b/c I can hear it and then all of a sudden its just gone............ then ill park it to do something and come out and start it and t will do the same work and then its gone....
Old Aug 20, 2003 | 04:14 PM
Josh's Avatar
Dr. Doom
sounds like you're running lean because of the O2, but i've been wrong b4.
Old Aug 20, 2003 | 04:16 PM
no thanx for advice anything will help u know n e other ways to troubleshoot
Old Aug 20, 2003 | 04:31 PM
MattC's Avatar
like he said before, check the solenoid, clean the screen out, check ur oil pressure, and all of that.
Semper Fi
Old Aug 20, 2003 | 04:37 PM
Josh's Avatar
Dr. Doom
i gave you advice, not my fault if you don't take the time to read.
