V-tech problem
Old Aug 20, 2003 | 04:40 PM
RARE1NONLYCIVIC's Avatar
ni i meant no problem but thanx for advice my bad for wording it wrong
Old Aug 20, 2003 | 04:44 PM
Josh's Avatar
Dr. Doom
if your solenoid is bad = get a new one
if your oil level is low = put more in
if your sensor is bad = get a new one
if your VTEC filter is dirty = clean it with a lil bit of brake fluid or buy a new one
you may aslo want to top off your coolant and check your ECU codes, if you're throwing any codes, address the problem on that basis.
Old Aug 20, 2003 | 11:16 PM
gotvtec20's Avatar
Import Tuner
i agree. also, check the wiring around the solenoid and just make sure nothing is loose or exposed.
03' BMW 330XI
Old Aug 20, 2003 | 11:20 PM
Crab Cakes's Avatar
So Lost!
Did you check out all the things that were told for you to check...Let us know if you fixed the problem...
Im The Original Crab!
