TECH: Main relay replacment
Guest
Posts: n/a
We see this from time to time here, and agreed it's a plague to the older obd0 (EF) crowd...
Main Relay Replacement
-by Phoenix
Besides the igniter, older Hondas suffer from main relay failures as well. Project FFastlap is no exception. I thought it might be the igniter, but swapping it out with a known good unit made no difference.
FFastlap simply refused to start up reliably -- especially after very short drives. I was in denial of the main relay being the culprit, I actually contemplated replacing the fuel pump first. Thankfully after reading IT racers' experience with the relay, I decided to give it a try before going through the hassle of the fuel tank.
Not sure the main relay is the problem? Check out Auto Repair's web article(http://autorepair.about.com/library/.../aa010301a.htm) at about.com, it will give you some diagnostic information and more technical information.
Click for rest of article... http://honda.hybrids.jp/tech/parts/main_relay.shtml
-by Phoenix
Yeah the infamous Main Relay.
Also seems to affect some 5th Gen Accords as well.
How to fix it solder style...
"Insert some random quote(s) that most people won't understand or care about"
Guest
Posts: n/a
