Please help me!
Please help me!
in replacing my suspenson there are a couple of things that need replacing. one is the self-locking nut on the bottom of the fork on the front suspension, is a standard self-locking nut, or is it a nylock nut (the kind with a locking nylon insert)? i really need to know this asap, and also, can I get these from any hardware store ie Home depot, Lowes, ACE? looking at my factory service manual made me wonder these things. if it helps you, i'm looking at the factory service manual for 96-00 civics, on page '18-17' for damper removal, since they have the same suspension as my teg. thx guys! also just for info, specs on the self locking nut is 12mm x 1.25 thread pitch.
Guest
Posts: n/a
self locking nut??? are you talking about the nut on the ball joint on the bottom of the hub assembly??? if so no i would not use shitty hardware stuff... suspension stuff is SERIOUS!!! i would get OEM parts for that... i might have some extra nuts around here if you need...
-Keith
-Keith
i know in doing my preludes suspension i got all new self locking nuts from honda, it wasn't very expensive. just go to honda, they'll pull up a graphic display of ur suspensiona nd u just let them know which nuts or bolts u need.
Semper Fi
Aim and Yahoo- Inkedupordie
Semper Fi
talking about the nut and bolt that holds the fork to the LCA on the front. at the top of the fork, this bolt is a pincher bolt, and at the bottom, this a self-locking nut. btw...any honda service locations open today or tomorrow?
if u hurry u could get to honda tampaland. i THINK they are open till 6, u may want to call first. i usually make my trips on fridays (payday) so i don't know if they are open on sundays. i would think they are.
Semper Fi
Semper Fi
and get an OEM nut, that's would suck having anything happen to that nut. i mean really suck. and if it was b/c u got it at ACE u'd kick urself in the ass numerous times
Semper Fi
Semper Fi
i was up at ferman acura earlier today and their parts dept isn't open on weekends. i'm going to stick with OEM, i was just wondering if these were standard nuts that were readily available. thanks for the help!!!
no problem. honda has them in stock garunteed. if they don't than they must have had 50 people come in and ask for the same nut. what were u doing on ur suspension exactly?
Semper Fi
Semper Fi
