PDA
View Full Version : Nissan/Infiniti Tech
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184
  1. head lights flash in s13
  2. grr not starting.
  3. Help with oil pump drive spacer
  4. JDM zenki cluster into USDM kouki S14
  5. Running lean under load..
  6. Ka24de rebuild kit?
  7. AC Agony...
  8. Tires Rubbing on stock shocks!!! wtf???
  9. sr20det oil filter ???
  10. s 14 question
  11. 91 240sx weird wiper problem
  12. timing or fuel issue?
  13. S13 Clutch Pedal Bracket Spacing ???
  14. Spark Plugs????
  15. underhood liner 240sx ?
  16. Brake Question
  17. Wiring help needed, cash for help
  18. Brake issue FAIL!
  19. oil pressure question??? need help
  20. S13 ka24de header question
  21. Q45 5 lug swap
  22. Setting up power source...
  23. S14 trunk torsion bar install
  24. clutch pedal reinforced
  25. Exhaust port/cumbution chamber coating ??
  26. Brake Light Stuck On (99 Altima)
  27. Why is my 300zx twin turbo blowing blue smoke?
  28. 1990 300zx twin turbo blowing smoke from the exhaust. Need help
  29. annoying s13 problem
  30. 300zx twin turbo wire color question
  31. s13 swapped RB25DET will not stay started
  32. s13 sr20det breaking up. need some advice
  33. question to Z32 guys
  34. Custom Stainless exhaust in the Brandon/Tampa area?
  35. s13 tien super drift coilover need help ASAP THANKS
  36. Wiring harness help plz
  37. RB20 power steering pump question
  38. battery relocation mess up
  39. question about bumper light?
  40. Help tuning S13 KA-T Nistune
  41. Wiring gurus, need your help!!!
  42. Welding your diff.
  43. sr20 turbonetics turbo and down pipe identification...Help...
  44. S14 Wheel/Tire/ Offset combination
  45. sr20det transmission grinding problem need help!!!
  46. sr20det coil pack issues
  47. undoing a sleepy eye mod help
  48. dash lights/running lights stay on.....HELP
  49. USDM Dash harness with JDM chassis harness
  50. Dyno Jet Dyno vs Mustang Dyno
  51. High Idle problem!!!
  52. 240sx electrical Issues.. Please Help!!!
  53. Anyone ever make your own motor mounts?
  54. Stretch Tire mounting in Tampa (Near Dale Mabry/ Linebaugh)
  55. Any1 ever cut / weld oem rear fenders / rear clip on a s13? Any tips or suggestions?
  56. Resetting ecu / pulling ecu code ka24de
  57. s13 24v greddy intercooler kit help!
  58. What are these and what do they do?
  59. BEE*R Limiter help
  60. S14 7" flip out fitment issues?
  61. S13 sr20 milky oil
  62. RB25DET wont start please help
  63. silly soh timing question
  64. sr20det valve shimming.
  65. Looking for someone with a sil coupe
  66. Smart tuner people, tell me why this would be a bad idea....
  67. Lightweight batteries
  68. Diff questions...
  69. HELP! Installed new pads on the Z, weird noise?
  70. best tire size on a 10" wide rim for an s14
