Quick question! S13sr into s14!
Quick question for all of you. Currently swapping an s13sr into my s14. Hooking up my lower harness and I have an extra wire, not too sure where it goes. I am searching through thousands of pictures on google/zilvia/nico but was wondering if somebody on here might help me out. It is a black/red wire. Same as the main from the positive to starter but smaller and has a 90 degree eye crimped to it. Does it go to the positive? Don't wanna hook it up wrong and blow a fuse. The harness is out of a 5 spd s14. Any info would be awesome. Thanks guys! Also it is pointed toward the battery (where the old one was) Here's the wire I'm talking about.
Some dude on 240sx forum-there's no such thing as original in the 240sx community anymore. you're either sick with it or welfare status
I believe I found it and it says, connect to switched power at fuse box. Any ideas?
49 views and nobody has any input?
Edit: picture of wire posted. Totally different the. Perceived
I love my honda, when it pressure washes my nissan.
Build threads
S13 coupe
https://www.tamparacing.com/forums/n...ht-purple.html
Kouki
https://www.tamparacing.com/forums/nissan-builds-projects/688726-kouki-project.html
Build threads
S13 coupe
Kouki
It wont start as of now. I extended it to my positive on my battery and went to hook up the negative and it just started sparking like crazy off the negative, thats not right.
Oh that looks like it goes on the starter, there should be a small place to hook it up on the rear passenger side of the starter, possibly a terminal boot covering it.
Build threads
S13 coupe
Kouki
Build threads
S13 coupe
Kouki
The one for the starter is already hooked up, with a boot over it. Do you have an s14? think you could take a picture of your fuse box or look at it closely and see if the black/red wire connects or goes into there somewhere?
Alternator rofl my bad, sidepost of fuse box is only other guess..
Build threads
S13 coupe
Kouki
Build threads
S13 coupe
Kouki
I'm driving, but there should be a post comming up from the riverside rear corner of the fuse box.
Edit: driverside lol
Build threads
S13 coupe
Kouki
Build threads
S13 coupe
Kouki
Yeah I think that is where it goes, do you have an sr in your car? Pm me
