Best Clutch For RB25?
whats the best clutch for an rb25det?
i have a spec stage 3+ right now and it is garbage to say the least. cant even hold 238tq anymore(8 months old, properly broken in)
so what do you run?
or what would you prefer/go with?
thanks
so what do you run?
thanks
Skyvia - The Best of Both Worlds
Project.O In Full Effect...
Ride(s)
Green Lightning 10r :'( Sold :'(
Project Silvia :'( Sold :'(
2002 BO Lexus Is300 Rip :'(
2003 BO Lexus IS300 Sport Design (Project Altezza)
2010 Black Louts 10r :'( Sold :'(
1996 200sx Ser gtir swap 350hp SOLD
***More to come***
Car Stereo Installer for hire
come to me for your Audio Needs!!!!
Ride(s)
***More to come***
The clutches are pretty much universal, you get the flywheel specific to your vehicle/engine
Disc packs that match your transmission spline
RB uses same flywheel bolt pattern as KA24DE, search a bit and you'll find the flywheel, then you need clutch assembly and disc pack, discs will be for 1" x 24 spline
tilton does have the cerametallic line for a little bit better streetability, as most would probably find the normal sintered discs a bit too aggressive, although its all going to come down to how much power you're trying to put down.
For affordability the tilton stuff is available widely, used from nascar and other racing stuff on ebay, or simply just a single tilton or quartermaster, still leaves you with the upgradability of the common 7.25" stuffs.
thanks for all the info.
ive been looking for a tilton rb or ka flywheel but havent had any luck so far.
and cant really find anything good from rps. im thinking about just trying to find a used os giken and rebuild it.
im gonna keep looking though.
And for the record, im still not sure why more people arent running 7.25's on SR's
The flywheel is available for that too, and even if you just want a "daily driver" setup you can get a single organic 7.25, I believe even that is rated for 350 ft lbs iirc ?
