BEE*R Limiter help
Bought Buriantsu Bee*R limiter and installed it exactly how it is suppose to be installed
followed this guys write-up and know his worked cuz i have seen him slide CFRC with it plenty of tiimes
https://www.tamparacing.com/forums/ni...all-guide.html
With the Red REV set on 0 which = 2500 rpm and the gain at F which shoud make the car back fire pretty good it does nothing just goes stright thru the RPMs, the red light will come on at 2500 rpm but wont sit there and flash
if anyone has any clue why its being dumb lmk plz thanks
Do you know for a fact it was working when you bought it? I have heard of these going bad
...and then I wondered why I was on Stanceworks forums...
Originally Posted by PJ Prendergast
i went to a scrapyard in Kilcock today looking for my 180sx tail lights, no luck though
I think 0 is off. That pic robyou posted is confusing. Your sposta tap into the wires not cut them off from outputting into the outgoing harness wires which is what it looks like. Also, Do you have a test pipe? Also make sure you have the right loopt wire cut.
