Brake Light Stuck On (99 Altima)
Old Jul 15, 2011 | 08:54 AM
Jala47's Avatar
Oh no!
Default Brake Light Stuck On (99 Altima)
The brake light on my 1999 Altima is stuck on, even with car ignition off and key taken out. I already removed the fuse to cut the light off.
I'm assuming it's the brake switch and I've heard it can be easily repaired with a nickel or a nut but I'm not sure exactly where to place it and if it's even recommended.
Now I did find some rubber/plastic bits on the ground the day after this happened if that is any help.
Also I did search prior to posting this and found nothing. Currently skimming Google for help.
Patiently Waiting...
Old Jul 15, 2011 | 09:02 AM
boca's Avatar
Old School TR member
Thats the rubber grommet behind ur brake pedal...
Its a very cheap fix.....u neeed to crawl under ur dash and look at ur brake pedal..
U should be able to get the part from discount
Originally Posted by Liquid
Haha we started it.. we finish it.
Old Jul 15, 2011 | 10:02 AM
Empire's Avatar
buildin' it
yep. that's the piece that broke.
get up under there and you ought to be able to see where the pedal comes up and where it would push the switch to turn the lights on and off. there is a hole there where that little rubber/plastic piece used to be.
you can either get a new piece, or stick a nickel or something up there. pretty much anything to cover that hole will work. I've always used a spit of jb weld and a nickel in my 240's since that is a common occurrence.
Old Jul 18, 2011 | 07:17 AM
Jala47's Avatar
Oh no!
I appreciate the help, thank you
fox3streetracer
For Sale/WTB TRuck
18
Jun 10, 2010 01:35 PM
fox3streetracer
For Sale/WTB TRuck
Mar 10, 2008 01:31 PM
_Charles_
Nissan/Infiniti Tech
Nov 15, 2004 07:40 PM
jeffronismo
9
Jul 6, 2004 11:51 AM
Big Chris
Jun 5, 2004 04:59 PM
