j30 5 lug conversion for s13?
what would keep me from running a j30 hub and spindle on s13? the only thing i see causing a problem would be lca's and possibly drilling out the strut.
So there it is, J30 5lug hubs can be used easily with the entire upright, otherwise the use of a press and a few hours is required to swap races and for the DIYer it's probably more work than they can handle. This of course will only work if using Schassis rear brakes, the J30 ebrake assembly is different from the Z32 and will not bolt up the same way, plus the backing plate has to be cut off if you're going to use a larger rotor, eliminating the ability to attach the ebrake anyway.
http://www.freshalloy.com/forums/sho...d.php?t=135746
and here is some info regarding the front swap...
New discovery in 5 lug hubs for S14's - Nissan 240SX Forums
Jack1
For Sale/WTB Honda & Acura
5
Jan 9, 2009 02:57 PM
