s13 with j30 noise help
I have a s13 and I just installed a j30 differential that I purchased from someone here. I used royal purple oil "almost 2 bottles" when I installed it the thing runs fine grips hard.
The issue is now i have a loud whine coming from that area that you can hear when ever you press on the gas. If i am coasting you do not hear it only when pressing on the gas. this noise is lound and i cannot figure out what it is. Any ideas would be appreciated.
thanks for the suggestion, i looked when I had the cover off and did not notice any shims added
the noise sounds like a honda transmission in reverse but just a little louder
i have a welded diff that wines but its been doing it for 3 years now. when i first got it it was very loud. i changed the fluid (what came out was very clean) to a thicker lucas gear oil and it quieted down alot. still wines a bit
TR "Old Skool EF" Member #48
99 Mitsu Eclipse GS-T DD
91 Honda CRX Si
91 Honda Civic Si
91 Honda CIVIC Si FOR SALE da front brakes. mint interior, 650 buks
91 Honda CRX Si
91 Honda Civic Si
mine didnt whine. drove on it for 2 years. but its one of the things posted in this thread...
Originally Posted by Empire oh no. another ass hole 240...
Thanks for the input, replaced both axles last night no change I am going to swap it out with a open tomorrow and see if the noise is there. That should narrow it down some more.
lol it would be funny if someone welded it thinking it was an open diff
91 Honda CRX Si
91 Honda Civic Si
91 Honda CRX Si
91 Honda Civic Si
replaced with a open diff, and there is no noise so its def the j30. After searching around i noticed that are all j30s supposed to use bushings in the front to bolts?
