fuel pump wires smoking. need help asap
Old Mar 10, 2011 | 12:57 PM
zacxzx's Avatar
Default fuel pump wires smoking. need help asap
i smelt a funny smell and looked in the back and it was my positive fuel pump wire smoking. so i detached it quickly and haven't don't anything else since then.
the negatived wire seemed ripped out when i looked at them.
what do i do?
call or text 813 545 5477 if you can come to my house in hunters green i can throw some money for anyone who knows how to fix this.
Old Mar 10, 2011 | 05:01 PM
supreams14's Avatar
Hard wire it in with a new 30 amp fuse, 30 amp relay and 12 gauge wire. That will flow some high current so protect the wire and loom it where ever it might be next to or touching metal.
Old Mar 10, 2011 | 05:56 PM
RobRobking18's Avatar
call me puppy
dont hardwire it. just find the problem and fix it. or i can come, find the problem, and fix it for you, the right way.
Old Mar 10, 2011 | 06:24 PM
omgosh's Avatar
Why not upgrade since its broken?
If you get some 10ga wire, then put in a relay thats switched on by the stock wire, you wont see nearly as much voltage drop at the pump as with the stock 10 feet of 16ga or whatever it is...should cost about $20..
Old Mar 10, 2011 | 08:06 PM
miataspeed's Avatar
^ best thing to do to get a nice reliable power source for your fuel pump.
if you havent been in a small plane its worst, cause your eyes and brain say we are moving and your body says oh no we are not. eyes and brain go asshole we are moving, cant you see? body says fuck you we are not moving at all. so they fight and fight and eventualy your body says, you know what fuck you brain, see if you can stop this!! then you throw up.
Old Mar 10, 2011 | 09:08 PM
omgosh's Avatar
In the DSM world the "FP rewire" is pretty much the first mod on the list.
RRE did some testing to prove it if you're interested.
http://www.roadraceengineering.com/f...pflowrates.htm
Old Mar 10, 2011 | 11:01 PM
supreams14's Avatar
Havent slep in 36 hours, Deff find the problem first though.
Old Mar 11, 2011 | 05:14 AM
Empire's Avatar
buildin' it
its probably the combination of a crap ground and the fuel pump starting to die. as they die, the voltage draw goes up. the stock wire can only flow so much voltage.
If you run a new wire, make sure you do it right and not some half assed wire hanging off of the battery terminal that goes straight to the fuel pump. And don't just shove the wire into the fuse spot either.
Old Mar 11, 2011 | 05:24 AM
rhart's Avatar
Because race car…
^ lol
If it has tires or boobs it's going to cost you money...
Old Mar 11, 2011 | 07:30 AM
Blackzenki82's Avatar
(OO\____/OO)
all you guys are wrong....
the smoke is perfectly normal, everyone has it, just kinda drive around and hope it doesn't get worse, then, when you wake up to go to work the next morning, your car will look like this!
for serious though, just wire it back up, put some electrical tape on the twisted together wires (you know NOT to solder anything), just make sure the twist is tight, so you have a steady contact, and just daily the car, worry free!
Originally Posted by sean1
Shit'll buff out.
