dash lights/running lights stay on.....HELP
Old Jun 28, 2011 | 12:43 PM
ch pimp's Avatar
Default dash lights/running lights stay on.....HELP
dash lights/running lights stay on at all times even when key is off and out of ignition. I've traced wires and didnt find a short, disconnected the ignition cylinder. plug and played with fuses and relays cannot find out the problem. Anyone give me any pointers would be greatly appreciated. THanks
text 352-403-7107
Old Jun 28, 2011 | 01:08 PM
Turbo Mat's Avatar
Did you disconnect the battery? Don't know if it will help, but worth a try.
1995 Emerald blue S14 (DAILY)
1996 Emerald blue S14 (Weekend car)
1995 Champagne S14 (trailer)
1993 black s13 convertible (beach cruiser)
Old Jun 28, 2011 | 01:39 PM
ch pimp's Avatar
yes and as soon as I reconnect it, lights turn back on
text 352-403-7107
Old Jun 28, 2011 | 06:48 PM
ch pimp's Avatar
tracked down all wires, no wires seem to be cut or grounding out all the way from tail lights to fuse box by driver side kicker panel. I've tried a new TCU, illunimation dimmer, and the light toggle switch thing. Nothing has fixed it. Checked all connections on lower harness, even replaced the lower harness. Still NOTHING. harness has already been tucked in fenders on both sides and have nothing worn down on them to be causing a ground. Only two ways to turn off the lights on said gauges, a/c controls running lights and tail lights are to disconnect the alternator fuse or battery. I REALLY NEED HELP THIS IS A PAIN IN THE ASSSS!!!! thanks again
text 352-403-7107
JdM_Boii
Apr 13, 2011 04:11 PM
nickh2130
Aug 10, 2009 12:28 PM
rideordie5740
Nissan/Infiniti Tech
7
Mar 15, 2009 08:26 PM
ADAM
Feb 7, 2006 09:35 AM
25 to LIFE
Nov 15, 2005 04:32 PM
