body wiring difference.
is there a pinout difference in a 1990 and 1993 240?
mainly talking about the clip that goes to the dash and the back of the car n whatnot that controlls the cluster fp...
Originally Posted by Empire oh no. another ass hole 240...
Just my .02...I know there is a diffference in harnesses between a Base and a SE...but as far as a pin out difference I dont know.
-Royce
-Royce
If it has tires or boobs it's going to cost you money...
i know that sohc/dohc part but i am talking non motor harness wise. is there a difference in the wiring under the dash?
Well you have to change the plug, or the pin outs for the dash harness to make your gauges work. So like I said, yes sohc and dohc are different under the dash. I thought that was pretty obvious?
im gathering info on my motor swap and the wiring layout info i have is for a 1990 i have a 1993 and was just curious if anything was different in the body wiring so i could make adjustments on my harness...
vh45de. i have the wiring diagram. it is just for a 1990 s13. i just wanted to make sure that it wasnt different.
