annoying s13 problem
Old Jul 14, 2011 | 03:40 PM
240Cyanide's Avatar
Function is my form.
Default annoying s13 problem
For about 3 days now my car cuts out past 4k rpm while driving. Goes past that in neutral. I pulled codes and had 14-front 02 sensor and a vehicle speed sensor circuit loop open. I cleared them and drove the car for a few mins and then rechecked for codes and it was all clear. Would a bad speed sensor be doing that?
Old Jul 14, 2011 | 05:30 PM
Z28ricer's Avatar
Doesnt see what you did
No, 85% of tampas nissan owners dont have functional speedometers / vss's.
Old Jul 15, 2011 | 06:17 AM
Empire's Avatar
buildin' it
I say it is a fuel problem, but it kinda depends on how it "cuts out"
Old Jul 15, 2011 | 07:03 AM
240Cyanide's Avatar
Acts like its hitting a govenor. The rpms will drop to about 3000
Old Jul 16, 2011 | 05:09 AM
240Cyanide's Avatar
Anything else?
Old Jul 17, 2011 | 08:43 AM
kshady's Avatar
when it cuts out do you mean it shuts off or wont go past 4000 rpms if it does go past 4grand its usually a mass air flow sensor advance auto parts sells maf cleaner but if it dies out when it hits 4000 then im not sure
Old Jul 17, 2011 | 08:51 AM
240Cyanide's Avatar
It stays running. The rpms just drop to around 3 grand before it'll start accellerating again
Old Jul 18, 2011 | 06:53 AM
Empire's Avatar
buildin' it
kshady has a point. It could be your MAF starting to take a shit. dirty. loose plug. maybe the seal on the sensor itself is going bad and getting moisture in there.
could always try unplugging the speed sensor too and see if that changes anything. Won't have a speedo, but the ecu won't know how fast it is going so that rules out the speed related idea.
could be something really dumb, like the ECU thinks it is in 5th gear all of the time and you're hitting a rev limiter.
hell, unplug everything off of the tranny and see if it still does it.
It would be pretty dumb if that was the problem, but you never know.
Old Jul 18, 2011 | 07:01 AM
-Mike's Avatar
Formerly IThaJokaI
maf wouldnt just stop, it would hit a limiter of sorts. Speed sensor wont cause an issue, I drove around for months with a bad VSS and it didnt do shit.
Old Jul 20, 2011 | 05:11 PM
240Cyanide's Avatar
Well it drove to gainesville today; on the high way it was fine.. I get off and drive a mile or two and then starts to want to die..like the rpms will just drop.. giving it gas wouldn't do anything. It would go down... eventually it would let me accelerate slowly and then sometimes it would die on trying to take off. Well it finally stopped working lucky I broke down near a advanced auto parts so I buy a new fuel filter...put it on and started driving home. it seemed fine on 441 for a while until I got close to ocala then it bstarted acting up again.. not wanting to stay running so I decided to try and push the gas pedal through the fire wall.. which seemed to work.. well it would keep it from dying it just wouldn't accellerate. It just got worse the closer I got to home.
Sorry about the story haha.
But I really need some input. What could be causing this?
Today was the first time I had a full tank in who knows how long. Could it be an overwhelming amount of gas tank rust going to the filter?
also once it dies i would try starting it, it would run for half a second and die..probably had to try starting it 5 times. it was amazingly fun while in busy intersections.
i also dont even have a working speedo... it stays pineed at just under 45 while driving
