- h22a vtec fuel injector??
- need my car wire tucked
- Acura Radio Code?!?!?!?
- wats a good high compression b16 or gsr block setup
- what injectors are better all around
- Correct a/c bracket for my LS into EK swap
- building a lsv
- Poll to have a clutch safety switch or not..??
- put gsr in 89 integra
- clouds and clouds of smoke.
- difference in mounts?
- 91 EF hatch b16a2 problems
- Please help asap H22
- 94 Legend - Motor "jumps"
- Fuel injectors are not important ... Are they
- need help
- 88 crx dx mpfi swap
- does anybody know the valve lash for gsr wit skunk2 stage2 proseries cams
- what are some good adjustable cam gears that wont slip for bseries
- why my 94 ls wont pass 3 grand
- how to mount Thule roof rack on 98 civic Hatch
- 0bd2 To Obd1 Bseries Conversion!! Need Helpp
- ek hatch d15b problem
- Help:95 Prelude seized the motor
- yesss...one dayy
- ERL-performance..??
- 00 Civic Hatchback DX Help Please.
- Power loss through drivetrain.
- how do i bypass clutch so can start civic w/o pushing in clutch
- do they make a turbo for a 1989 integra dohc zc
- how long does it take to change a head gasket
- Towing...
- i need a grill for my civic
- I need crx type r swap help
- lowering spring install?
- guys need help taking lug nuts from my civic 00 asap asap
- Stolen Ls/vtec Integra
- how do i do a single cam v from d15
- Fuel rail question...please help?
- ebay wastegate
- Y is my sunroof scrathcing my roof??? (VIDEO inside)
- Vtec not engaging, need help!!
- pm6
- What do you guys think of D2 coilovers?
- misfire in all four cylinders
- help! flooded car lol!
- Awesome Project..
- My axle slides out H22 EG
- h22 in EG question. the more responses the better. EcU question
- need radio harness diagram for a 93 civic!
- obd0 to obd1 questions crx
- does anybody an ef hatch spare tire cover i can trace???
- Help me Identify these cams!! Type R? *I Searched*
- Question about EG H22 axles
- crx
- 00 Civic Hatch DX
- 15x7 with +15 offset...will these fit a dropped DC?
- is it safe to put skunk2 pro seriies stage 2 cams on a stock gsr head
- welcome your new mod SuburbanNoize
- Need a GOOD shop
- need someone with honda knowledge, please help
- 89 crx si seats into a 91 hatch?
- Fuel pump and Main rely wont click WTF!
- jdm d15b swap which ecu??
- Question about Headgaskets
- help
- help me!! how do i torque my b16 block and gsr head down
- Hydrolock.Crank.Question (?)
- Help!! What is Diffrent with 97 Accord V6 hood from 4cyl
- Help with a/c
