Got some $$ to spend, what should I do next?
Ive got a 91 Crx Si w/b17 swap...nothing done to the motor. I have a Zex 55 shot, stage 2 clutch, Gator axles, Neuspeed lowering springs, that's about it. Seeing as how Im not a genius when it comes to this sort of thing, I wanted to get opinions of what I should do next? NO turbo or superchargers, Id like to stick with the nos and build the motor. I'm also done with the swaps as this is my 4th one. Opinions please
TR "Old Skool EF" Member #012
91 Honda Crx Si & 03 Lightning clone
~*~Ellie~*~
RIP Cisco Ramos, RIP Brian Nichols
~*~Ellie~*~
About $3k but Id also like to put some of that into my Mustang, at least get some minor rust fixed
~*~Ellie~*~
~*~Ellie~*~
theres a LOT of choices..need budget/power goals first..
if it were me..id get some eagle rods and high comp pistons ~11.5:1 and rebuild the bottom end..or figure out an oem piston setup to bump up compression..
OR you could start building your head now..do valvetrain and get a nice set of cams..
Or you could get all your fuel done for whatever hp u expect to push and get ur car converted to obd1 so you can get a good tune when u do decide to upgrade other things..
I am also in need of a new exhaust. This damn Magnaflow is killing me with as loud as it is
~*~Ellie~*~
~*~Ellie~*~
Head job,cams,obd1 swap,chipped ecu,good coil-over set up,traction bars,camber kit,LCA's,good alignment(no Tires Plus)then bump it up to a 75 shot & clock some 12sec runs.
"THE REAL HONDAMIKE" ASE Master Technician
"Imitation is the highest form of flattery", but clones can get it wrong because we are promoting individuality and being proud of yourself.
