93 civic hb H22A swap help!!
I have a problem with my H22 swap. It's obd1 and im using the p13 ecu. Whenever i start the car it idles a bit rough and when i step on the gas it rev no more than 4k before it starts to choke or sometimes turn off the engine on it one due to the choke. Could this be a vacuum problem or what? anyone? If anyone around the bay area know how to wire and hook up an H22 ill willing to pay to get it done asap.
do you have any check engine lights?
XXX Motorsports - In House DynoJet
850-457-DYNO
BBmoto Built/Tuned - Where honesty meets quality
Authorized Neptune Dealer/Tuner
Authorized eCtune Tuner
Honda OBD1 CHIPPING SERVICES
850-457-DYNO
8.64 @ 81.22mph
All Motor H23vtec Prelude (stock head)
+2
If it is, bring it to a shop listed in the tuner directory on https://www.tamparacing.com/forums/h...directory.html
+2
It's not run able. does anyone here know how to burn chips or recommend any shop that can do that.
You can't chip a p13 ecu with crome/hondata/neptune/uberdata etc.
So that honestly wouldn't resolve your issue.
It sounds to me like you may have mix-matched plugs in your engine harness or a bad ecu etc.
listen to that guy ^^^
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Your answer is on https://www.tamparacing.com/forums/ho...directory.html
1. You need to check your codes while using your p13.
2. You need to resolve every MIL you can.
3. If you can't handle this you need to have the car towed to a shop that can.
you got PM, give me a call
813-951-5346 Mario
Theres plenty of people on here that can vouch for me
813-951-5346 Mario
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
TR H2B crew #2
