Help Me Pls!!!!
I drive a 94 accord vtec manual and everytime I try to get the most power out of it, the rpms wont go past 5.5 rpms so i dont get the power from the vtec...does anyone kno wat it could be or how i could fix it?
Is your check engine light on ?
If so, check your codes & get back to us...
have you changed the timing at all? does it stop at 5.5k or just does it start to break up ?
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
No i havent changed nething at all...i heard someone say that i mite need an ecu because vtec engines that are built in the US don't have the vtec working just the set up which means i would have to get a new ecu for my vtec to start working...
