Question ????
Question ????
alright This Is Kind Of A Dumb Question But I Still Need A Few Other Opinions ???? I When To Turn My Car On And Nothing Happen Evrything Lights Up ,,fuel Pump Is On But No Crank No Noise At All I Changed Batterys , Changed Starter And Still Nothing ????? I Had A Few People Tell Me It Might Be A Clutch Switch Others Tell Me Alternator??? My Fault I Have A 95 Civic Ex Coupe ........ Please Any Answer Or Opinions Would Help ...thanks
http://www.facebook.com/WiderWerks
Most likely a bad clutch switch. Its a free fix you could put a paper clip in the connector or anything to "jump" the two wires on the connector. Also if you find peices of rubber on your floor near the pedals you'll know for sure it's the rubber boot came off.
Ricky
Ricky
make sure you replaced and re-tightened all the wires going to the starter. as well as check your grounds.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
broken teeth on the fly wheel?
by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
check battery wiring. you said new battery? if ist been sitting a wile it might need a jump. alternator or distributor could be at fault.
do you here clicking? or nothing at all?
2001 BB6 - 2003 R6
2001 BB6 - 2003 R6
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Yea I Bought A New Clutch Switch And It Still Did The Same Thing ...... Nuttin I Forgot To Metion That If I Push The Car And Pop The Clutch The Car Will Start No Problem And Run All Day Im Stuck Here Guyz Lmk Thanks
