Need Ef Help Asap!!!!
Old Aug 16, 2007 | 05:28 PM
Dltboy70's Avatar
Default Need Ef Help Asap!!!!
I have a 91 hatch with a d16a6 i have done a 5spd swap and mpfi swap... they both were done with NO problems.. i did the mpfi swap with obd1 injectors and worked fine. but now to get to the point I was driving this morning and all was good i got bout 3 miles away from my house and the car started actin like it wasnt gettin fuel(i have half a tank)!!! i would press the gas and it would like bog out and not go any where it also back fired once or twice then it jus stalled. i tried turning it on and it will crank but wont start. it started a couple times butonly for a sec and if i tried to touch the gas pedal it would cut off. i have checked all wiring, timing, and changer fuel filter!!! anyone have any other ideas???
Old Aug 16, 2007 | 05:40 PM
SmokinS13SR20's Avatar
That ginger...
Why did you do the MPFI swap, was the chassis a dpfi running the A6 like that and you decided to finally do it?
Old Aug 16, 2007 | 05:48 PM
Dltboy70's Avatar
BINGO!!!!! was waitin for ressistor box but i used obd1 injectors instead was runnin fine but never really seemed like it gave the hp gain it should have!!!
Old Aug 16, 2007 | 06:29 PM
Dltboy70's Avatar
ANYONE with ideas????
Old Aug 16, 2007 | 07:45 PM
Old Renegade's Avatar
Cool Runnings
are you getting fuel? could be that your fuel pump died or is dying.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Aug 17, 2007 | 06:32 AM
Dltboy70's Avatar
fuel pump was replaced 3 weeks ago....
Old Aug 17, 2007 | 07:26 AM
Cool Runnings
if your fuel is fine look into your ignition. check the rotor in your dizzy cap. make sure it is not loose and all the points are clean. also make sure the main relay is functioning properly and not being intermittent.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
