>>>Need a DIY D15B7 Timing Belt/Water Pump Install guide<<<
Old Aug 21, 2007 | 05:56 PM
sirt8669's Avatar
私は昼食のためのあなたのお母さんを持っ ていた
Default >>>Need a DIY D15B7 Timing Belt/Water Pump Install guide<<<
Just as the title says. Changing all the belts but really need a guide for the timing and water pump.
Let me know!!
Thanks in advance,
Tony
Old Aug 21, 2007 | 06:37 PM
BIGCOLT45's Avatar
dude just follow the timing marks and buy a chilton
Old Aug 21, 2007 | 07:12 PM
sirt8669's Avatar
That will be my last resort but I see DIY guides for most of the other motors but not mine, atleast so far in my searches.
Old Aug 21, 2007 | 09:03 PM
mug's Avatar
mug
Hey Mr Toilet Im The Shit
Honda-Tech.com: Honda Civic/Del Sol (1992 - 2000): [FAQ] Complete DIY How To: Timing Belt/Water Pump Change on a D16Z6 - lots of pics!
Their you go same process dont matter what motor.
Also alot easier if you use a impact on the crank pully but thats up to you.
rangcrx's Avatar
engine building &amp;amp;amp;best
its not to hard,but i would at least try to find someone to help you out with some steps,a book will tell you how to do it but timing is tricky!buyt just one step to help you undo the drain bolt on the front of the block its a big 19mm bolt to drain out the fluid so you dont have it comeing out the water pump when you remove
i love AUTOZONE
Old Aug 21, 2007 | 09:34 PM
sirt8669's Avatar
Thanks for the info guys. So, your sure about it being the same, basically cause its a D series but having VTEC won't make a difference right?
Oh, also, my roommate is helping me with this and he has done one honda before but mostly works on American Muscle cars and such.
