So.....My motor seized. (PICS)
on
So my motor seized a week ago today and I finally took it apart. Some pictures are a little blurry.
:Just the over view after I pulled the head:
:Close up of the seized piston:
:The rod to the seized piston:
:Rod again:
:This is the culprit. Was found wedged between block and rod:
:A Couple pictures of the inside of the block where the rod bolt was wedged:
Can you say f***ed?!
Setup is/was a sleeved B20/Vtec Turbo on 8lbs.
:Rod again:
B20 Non-Vtec Turbo: 275whp/234wtq @ 8 psi 2/10/2007
LS/Vtec Turbo: ???whp/???wtq @ ? psi (Secret )
Tuned by John Vega @ Phearable.net
that sucks
New sig. coming soon
Code 52 VTAK On A Switch
MCOR Automotive LLC
http://www.mcorautomotive.com/
PM MCOR for any electronics, upholstrey, accessories or window tint (813) 362-5454
They will take care of you as they did me
MCOR Automotive LLC
That sucks. What brand of rods were those? Did you use a good torque wrench or stretch gauge during the install?
engine building &best
on
was the crank resized?thats sucks i see this alot when you spin the bearing you can tell the piston hit the deck was it a gsr head?good luck with it all man that sucks
i love AUTOZONE
i love AUTOZONE
on
Stock B20 crank. It is a Type-R head. Head seems to have no damage.
on
well thats good you saved some money there..how long was it run for?where you racing at the time?just asking im rebuilding a motor for a kid right now with a b20 that let his"dumb"friend drive NEVER driving a stick he said.well i guess he over reved shift 2times and spun the bearing and his pistons just did like your hit the oil passage then just tapped the top of his gsr head just left a small imprint pretty funny
i love AUTOZONE
i love AUTOZONE
Wow, I have never seen that happen.
on
on
damn that sucks then must have been something easy like stated above like loose nut just worked its way off then out..damn you build it yourself or have someone pro do it?
i love AUTOZONE
i love AUTOZONE
on
Myself. Its been together for a while now.
