idle bounces.. !!!! ;(.. Y!!!!!
Old Aug 12, 2007 | 10:02 AM
wasrelgood's Avatar
Default idle bounces.. !!!! ;(.. Y!!!!!
i have new plugs, wires, rotor and just replaced the fuel pump.. my idle still sits very low and seems to go lower as the car gets hotter. and wen i put it in park( its automatic) the idle drops.. wats the cause and wats the soloution.. fyi. its a 1992 civic hatch . D15B7
Old Aug 12, 2007 | 10:19 AM
Gixxer's Avatar
Hide your daughters
Bad IACV? Bad PCV valve? Vacuum leak?
Old Aug 12, 2007 | 11:06 AM
JH26's Avatar
ΜΟΛΩΝ ΛΑΒΕ
+1 on the IACV or most likely it sounds like a vaccum leak.
Old Aug 12, 2007 | 01:28 PM
crix's Avatar
:mugen member:
throttle screw too tight or
fast idle control valve too loose or tight
iacv should set a code if not operating correctly..
Old Aug 12, 2007 | 04:32 PM
wasrelgood's Avatar
i will check the iacv tomorrow morning. i was told how to clean it so ill check that. how do i know if there is a vaccume leak?
Old Aug 12, 2007 | 05:42 PM
SmokinS13SR20's Avatar
That ginger...
Take off the IACV and spray it with some carb cleaner to get all the soot and carbon build up outa there
Old Aug 12, 2007 | 06:00 PM
wasrelgood's Avatar
ok.. but how do i check for a vaccume leak?
Old Aug 12, 2007 | 06:34 PM
alwayzblazed's Avatar
Get'em Started Early
u could hear a vacuum leak ... maybe just need to advance the distributor
cause u say it bounces in the title but in the post u say "my idle still sits very low and seems to go lower as the car gets hotter."
i dunno good luck
Old Aug 12, 2007 | 07:15 PM
crix's Avatar
:mugen member:
after that bs talk doesnt work ... haa haa sorry ILL b a dick some times check what me dumb ass says if ILL show no harm no faul
Old Aug 12, 2007 | 07:38 PM
wasrelgood's Avatar
wen i start it up it sits low. but wen i drive then put the car in park it bounces.. sorry for the confusion
