idle bounces.. !!!! ;(.. Y!!!!!
theres a fast idle control (under thrt..body) then theres a idle air(on intakmani) control which r u adjusting?fast idle needs to be loosen a little....
813-377-5505
Take your intake off... Then look in your throttle body with the car running and put your finger on the thumb sized whole on the bottom of the throttle body.
This will tell you if your fast idle thermo valve is causing your idle fluctuation.
