Breaking up in boost??
Just finished the turbo kit today and I took it down the road for a test drive and it's breaking up at about 5k rpms..
setup is a turbo b20z on 10psi with dsm 450's and a pherable.net ecu..
Maybe I wired the resistor box wrong or something?
2011 Kia Optima SX Premium/Touring package
whats ur fuel pressure reading at
The Myspace Page
Hero's arent born there american
made.
Aco. 53rd CSB LTF - TMT - 1st SQD
Afganistan Tour 2005 - 2006
- Its Game Time -
The Myspace Page
made.
- Its Game Time -
2. Are you running an msd system or stock ignition ?
Stay away from msd 6als
3. You maybe running too rich or too lean, you really shouldn't be romping on it without a wideband oxygen sensor such as the aem uego 6 in one gauge.
With every ecu we sell/provide we include information on using the proper plugs & getting the car hooked up to a wideband or going to a dyno tuner for tuning.
1. Check your plug gap & heat range
I'm using stock ignition
and usually when I do a car and get an ecu from you I plug it in and the car runs just fine, this is a timing issue, I'm almost sure of it now..
Your playing with fire without monitoring your a/f ratios with a wideband.
You should also sync your base ignition timing to 16.5 deg btdc.
