Tachometer going haywire
Old Aug 21, 2007 | 04:52 PM
rotary nation's Avatar
is full of Hondas =/
Default Tachometer going haywire
So I get my car back after being rebuilt a couple weeks ago and the RPM's go haywire when I'm WOT. Found out the dizzy was bad so I got a new one and it stopped doing that but now the wacky RPM's are back again. Any ideas? My speedometer works perfect. Also if this information helps at all, when VTEC is supposed to engage that's when the RPM"s go crazy and VTEC breaks up, like it goes in and out from loud to normal noise, very weird. It's a 94 Integra GS-R. Thanks in advance.
Old Aug 21, 2007 | 05:11 PM
rangcrx's Avatar
engine building &best
try checking item number 7 maybe switch out distributors
Shot at 2007-08-21
i love AUTOZONE
Old Aug 21, 2007 | 05:28 PM
Old Renegade's Avatar
Cool Runnings
yup, check 7 and make sure all the points in the dizzy are clean (the part that the rotor makes contact with), as well as the rotor too (that it is clean). make sure the vtec spool screen are clean.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Aug 21, 2007 | 05:31 PM
mtber's Avatar
Check the ground on engine harness located near the lower radiator hose.
Old Aug 22, 2007 | 02:15 PM
88RedRex's Avatar
Protected Taurus .45/.410
or try tighten the bolts in the distrubutor itself, had that happen to me on my B16, i just tightened the bolts and it hasn't done it since
New sig. coming soon
Code 52 VTAK On A Switch
MCOR Automotive LLC
http://www.mcorautomotive.com/
PM MCOR for any electronics, upholstrey, accessories or window tint (813) 362-5454
They will take care of you as they did me
Old Aug 22, 2007 | 03:47 PM
FC_V8's Avatar
kevin is your dizzy brandnew... give me a call and ill check it out for you.
Old Aug 27, 2007 | 02:00 PM
I took off the dizzy and I didn't see anything wrong with it, still looked brand new (I did buy it new from Advance Auto Parts). The tach still goes crazy after VTEC is supposed to enagage, and it still sounds like it's trying to switch to VTEC, it makes valve tapping noises when it does. I checked under the radiator and I couldn't find any ground, if you can show a picture where it would be located that would be great. I did find a ground not on the frame, I put a bolt on it and I found it to be the 2nd fan ground so now I have both fans running. Thanks for all your help, but unfortunately I still have not fixed the problem.
Old Aug 27, 2007 | 03:51 PM
mtber's Avatar
NEAR THE THERMOSTAT
Old Aug 27, 2007 | 05:45 PM
Okay, I checked the ground and saw what you were talking about John, it was grounded properly and bolted in, still receiving the same problems. I'm beginning to think it's the dizzy I got at Advance Auto. I'm going to go back and trade it in for another one, I'll come back if the problem persists.Thanks.
