b16 block and tranny with gsr head?
Old Aug 29, 2007 | 07:00 PM
tampakid101's Avatar
Thumbs up b16 block and tranny with gsr head?
some say its a poor mans type r because the gsr raises compression and some say it lowers compression but raises makes sense, just wondering what any other people think about that type of swap in an eg coupe what that would do and if it would be faster than a gsr. please post on thread i would like imput.
thanks, robert
k20 powerd project car complete take a look-
_||-|| (()) ||\\|| ||)) //\\_
"domestics"
Old Aug 29, 2007 | 07:06 PM
JR.'s Avatar
JR.
i think its the other way around, gsr block with b16 head.
98 talon awd automagic
Old Aug 29, 2007 | 07:13 PM
rangcrx's Avatar
engine building &best
i love AUTOZONE
Old Aug 29, 2007 | 07:16 PM
Gixxer's Avatar
Hide your daughters
Get ITR pistons and it will definitely raise compression.
i know thats what i thought as well but then if you think about it,the gsr head would raise compression, not drop it. the p72 head has smaller combustion chambers then the pr3 heads.
correct?
"domestics"
Old Aug 29, 2007 | 07:19 PM
Default compression
the compression of this swap is at 10-8-1 right now so i mean thats high
"domestics"
Old Aug 29, 2007 | 07:20 PM
Default w
Originally Posted by rangcrx
read what i just wrote though i thought the same thing
"domestics"
Old Aug 29, 2007 | 07:27 PM
rangcrx's Avatar
if you want power from your b16...bore it out to 82mm and use Ctr pistons and nice Jun/toda Cam with some itr inner valve springs and tt retainers
i love AUTOZONE
Old Aug 29, 2007 | 07:29 PM
Default i
i dont have a b16 im planning on buying this swap for my 95 eg coupe so im just trying to figure it out.
thanks for the info everyone keep it goin please
"domestics"
Old Aug 29, 2007 | 08:33 PM
sleepinsol's Avatar
starting over
all that b16 head will do is give the air a straighet path to the chambers. the chambers are bigger tho so ur really getting a head that doesnt flow any better than a gsr (ive seen the charts theyre pretty similar) and lowers the compression by .2 or .3 (not entirely sure). the gsr cams also have an extra 3 degrees of duration (give or take). so itl help that b16 out.
to clarify....the poor mans r is a gsr block with type r pistons n a b16 head with the type r valve train. the only thing the b16 head has in common with the type r is the casting. other than that the type r head is superior in every way.
i dont think the gsr head on the b16 will make it faster than a gsr bc it still wont have the tq. hope this helped.
