WAY too much oil pressure PLZ HELP!!
Old Aug 11, 2007 | 07:13 PM
Steve C.'s Avatar
hoollaa
Default WAY too much oil pressure PLZ HELP!!
My car would normally run around 85. now out of the blue it shoots to well over 100, at dle. Ive already changed gauges. i was told it might be the oil pressure relief valve, but i would like a second opinion! thanks for any help put forth!
Old Aug 12, 2007 | 07:31 AM
integrex's Avatar
could be that.....or there could be something blocking oil passages.....say like teflon tape or rvt....check the easy stuff first though
Old Aug 12, 2007 | 08:24 AM
-campy-'s Avatar
could be a bad oil pressure sensor or a blocked passage
Old Aug 12, 2007 | 10:30 AM
1BADP71's Avatar
E & I Certified
could be blown headgasket
Old Aug 12, 2007 | 11:16 AM
REDHATCHsi1.6's Avatar
Norm
negative
Meh.
Old Aug 12, 2007 | 01:34 PM
integra's Avatar
90% grind 10% sleep
could be time to get rid of it.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Aug 12, 2007 | 01:47 PM
rangcrx's Avatar
engine building &best
i myself block the pressure valve : o )but they might be right cause when i block them it runs about 85-95 but you could also have a something wrong with oilfilter or passage
i love AUTOZONE
Old Aug 13, 2007 | 03:11 AM
96ek's Avatar
Did you change your oil recently? I had the same issue then i changed to 5w-30 i use to run 10w-40.Maybe this helps.
Old Aug 13, 2007 | 05:36 AM
integra's Avatar
90% grind 10% sleep
i think its time to get rid of the car in my own opinion. i got a 91 K ready EF calling your name.
Old Aug 13, 2007 | 12:42 PM
Norm
you won't
Meh.
