PDA
View Full Version : Honda/Acura Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 [96] 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329
  1. noise from front end?
  2. anyone do wire tucks?!?!?!?!
  3. good honda shop in tampa area
  4. New Tranny or is it cheaper???
  5. question bout ef civic wit obd 0 pr3 vtec ecu
  6. cLined*2 = great seller
  7. Help with Civic power window
  8. odb1 or odb2 convertion
  9. a h-series into a EF
  10. rim question
  11. New car, few issues..
  12. tach jumping an sputtering?
  13. b18c1 rev capabilities
  14. hid help
  15. Ef Cluster To A Gsr Cluster Swap
  16. help ?????????
  17. Need Turbo Advise
  18. NEED HELP.. how to take off linkage..off tranny
  19. help plz....new to hondas
  20. b18b1 need more power
  21. obd-0 b16 into a obd-1 integra
  22. Ls turbo dyno graph
  23. 2 much VTEC *pics*
  24. New timeslip from Saturday's Track Event
  25. Idle Problem??
  26. taking off the crank pully?
  27. Ever heard of Vision Motorworks???
  28. where is my Code Plug????
  29. B Series Differential Q?
  30. d16zc swap
  31. Wire harness question.
  32. Car died
  33. NEED d-series flywheel torque specs..
  34. Question for those with jdm front end on a DC
  35. ARP TORUQE specs
  36. trying to locate
  37. ls eagle rods torque specs and how much hp?
  38. Help!!!!
  39. GSR swap into an 83 accord
  40. Valve size question
  41. y8 swap
  42. Shift kit
  43. Polishing Sun Damage From Headlights.. And Plastic Moonroof?
  44. Ls turbo dyno graph
  45. PLEASE READ Anyone with a spare H22 head around?
  46. white smoke
  47. 87 crx si fuel pump
  48. 02 sensor wiring . .
  49. ITR/CTR VS Skunk2/crower etc.. CAMS
  50. ??? Running some CEL Codes Help
  51. What cams should I us?
  52. O2 sensors??? Mysterious or am I retarded you be the judge!
  53. Slave Cylinder Q?
  54. 2000 civic ex question
  55. low pressure switch on 93 lude
  56. help?
  57. Need help with loaction of PCM on 97 accord
  58. Owners manuals?
  59. Engine swap for 1986 Accord
  60. LS pistons in a GSR?????
  61. parts needed to swap b18b on a ek hatch
  62. 94 integra ls auto problem help???
  63. i need my valves adjusted
  64. Bottom End Rebuild
  65. decent clutch for 91ls
  66. Car just shuts off??
  67. Small problem fixed: leafs in the a/c blower fan
  68. front end matchup
  69. help
  70. need info on how and what is needed to install dc dash in an eg
